chris-p-duck
| posted on 14/8/08 at 12:31 PM |
Zetec red line
Hi!
Does anyone out there know what the safe red line is for a 1.8 zetec?
Chris
scutter
| posted on 14/8/08 at 01:28 PM |
According to the Zetecinside website, 7000 on standard bolts! and only 400 more with ARP fitted.
ATB Dan.
| posted on 14/8/08 at 01:31 PM |
Got my rev light set at 6300 as it make peak power around 6100. Not much point revving it to 7K IMO
will121
| posted on 14/8/08 at 02:57 PM |
as above had mine on a Rolling road and after 6300 power tailed of steeply
procomp
| posted on 15/8/08 at 07:01 AM |
Hi
On the zetec fitted into one car we ran that had a DUNNELL rented engine in it. The rev limit had been set at 7500 using arp bolts and STD 130ps
cams.
On our race engines ( STD blueprinted) we run them all the way too 8000 using ARP bolts and std 130ps cams. But it would be advisable not to venture
over 7700 unless willing to take the risk it MIGHT come apart. You will need change a few parts for uprated items if moving up to higher spec cams (
even some of the hydraulic profiles ) as they can produce good power all the way to 8200.
Cheers Matt
Custardtart
| posted on 16/8/08 at 09:13 AM |
Mine's used for racing and it's set at 7300 on standard bolts. Peak power is at 7100, it's a standard 130ps on carbs with a mild cam
as the only upgrade.
They're only noodles
procomp
| posted on 16/8/08 at 03:58 PM |
Hi Custardtart. You are on ARP bolts. get that rev limit sorted and give it a bit more.
Although not as much as Steve at mallory.
Cheers Matt
chris-p-duck
| posted on 16/8/08 at 04:22 PM |
Does the under piston cooling of the 130 bhp unit affects its ability to rev or is the only limit the strength of the bottom end? I am guessing that
the cooling only affects the power it puts out and not the red line but thought I'd check..........
(Mine is the 105 unit with the 130 bhp cams so doesnt have the under piston cooling)
Chris
