Author: Subject: Can I use fuel/oil hose for water?
bassett
posted on 17/9/08 at 11:49 AM Reply With Quote
Hi, Basically as the topic suggests can i use oil/fuel hose for the water system as i can not find 6mm water hose anywhere as its off an R1 so has very small hose.
tegwin
posted on 17/9/08 at 11:59 AM Reply With Quote
Thats exactly what I did for my bike engine...
Cant see it being much of an issue given that fuel hose is chemical resistant and can withstand that sort of pressure...
Just dont try and do it the other way round
www.verticalhorizonsmedia.tv
bassett
posted on 17/9/08 at 12:07 PM Reply With Quote
Thanks for the speedy reply, was thinking also if anything it would be better as surely oil will be around same temp, always good to double check though.
Adam
Howlor
posted on 17/9/08 at 12:20 PM Reply With Quote
I used something like this if it helps.
Dock of the Bay
bassett
posted on 17/9/08 at 12:25 PM Reply With Quote
I had thought about that but if i bought that its going to be 5-6 times more expensive and id want to change the rest of the hoses. Might change them to all black silicon sometime in the future once its running and the wallets recovered
posted on 17/9/08 at 03:41 PM Reply With Quote
I've run 8mm fuel hose to / from the header tank without a problem. Not sure what Mr SVA thought about it but he didn't seem particularly bothered by it!!!
bassett
posted on 17/9/08 at 04:35 PM Reply With Quote
Good to hear Ben, hope it will get through as i think they are only really concerned with the fuel hose (ours are all marked as)
mad4x4
posted on 17/9/08 at 05:10 PM Reply With Quote
Tell you what a bit of fuel hose from the header tank will look more proffessional than garden hose or clear hose... Shouldn't be a prob.
Scot's do it better in Kilts.
Danozeman
posted on 17/9/08 at 06:04 PM Reply With Quote
Iv got it on mine and have used it for loads of cars in the past. Never had a problem.
Dan
