Author: Subject: getting the zetec to run
dunk3
posted on 22/9/08 at 06:39 PM Reply With Quote
hi again what else would i need to get my 2.0 black top running on injection using a megasquirt. cheers
novacaine
posted on 22/9/08 at 06:52 PM Reply With Quote
some form of suitable inlet and exhaust manifolds
it is likely that you will have to chop the sump (if its going in a 7 that is)
and some way of controling igntion
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
jacko
posted on 22/9/08 at 06:56 PM Reply With Quote
Petrol ?that may help
I will get my coat
Paul TigerB6
posted on 22/9/08 at 07:37 PM Reply With Quote
Gonna be using bike throttle bodies?? If so then a fuel pump from the same bike might be a good idea (and might influence the design of your fuel tank)
Sump (and oil pickup pipe) will likely need shortening (steel pan so not too bad), You'll probably want to consider a lightened flywheel, suitable starter motor / clutch / alternator etc. Bogg Brothers for an inlet manifold maybe??
jacko
posted on 22/9/08 at 07:57 PM Reply With Quote
Dunk send a u2u to Tim Windmill on here he has just finished the same set up as you his car is on the road so will know all you need to now + maps for the mega/ sq
Jacko
