MikeLR
| posted on 25/9/08 at 09:30 AM |
Alternator bracket
I have had two alternator brackets fail on the welds. This is the bracket that attaches the alternator to a Zetec under the carbs, can anyone suggest
a "quality" item.
Done some phoning around and not come up with anything yet.
Mike
| posted on 25/9/08 at 10:11 AM |
Very common failure on zetec's.
Its normally the bolts that shear tho and are a bugger to get out of the block
contaminated
| posted on 25/9/08 at 10:33 AM |
And very common Tigers! Tiger do a stronger item if you want to go down that road.
r1_pete
| posted on 25/9/08 at 12:35 PM |
Anyone know why they fail? the crossflows, pre crossflows, pinto's used similar setups to those most of us fabricate......
MikeLR
| posted on 25/9/08 at 12:48 PM |
One question - how can you tell which is the "Stronger" Tiger mount ?
Both of mine have broken off at the welds, back weld last time and yesterday;front weld.
Mike
