chrisg
| posted on 25/9/08 at 07:02 PM |
Unequal length handbrake outers
Today's hypothetical question.
If you had a handbrake set up where one of the outer cable sleeves was much longer on one side than the other would that effect the handbrake
efficiency?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
blakep82
| posted on 25/9/08 at 07:06 PM |
nooooooo i don't think so. the cable travel will still be the same.
the only thing i could think of is if the cable sleeve moves when pulling the handbrake, then it might be slightly less efficient, but if its securely
clipped in, then should be fine
________________________
adithorp
| posted on 25/9/08 at 07:40 PM |
Not a problem. Lots of tin-tops have different length cables.
adrian
http://jpsc.org.uk/forum/
chrisg
| posted on 25/9/08 at 07:59 PM |
Thanks chaps!
Chris
tomblyth
| posted on 26/9/08 at 05:01 AM |
as said no problems should come from the length. if you need some try hein gerick the bike shop (it universal clutch cable is 2.5mm same as some
hanbrake cables) the outside sleeve is easy it trim to size ( grind it to keep clean end). there about £3 each
