<<  1    2  >>
Author: Subject: BackFire_first engine start_Pinto_MJL_ZX6Rcarbs
black.viper
posted on 28/11/08 at 11:16 PM Reply With Quote
Originally posted by jacko
Is the fuel going in the carbs at the top ?were the two pipes join if so i think that's the wrong place that's the breather pipes and should be open to air
Looking at your photos i think you have blocked the pipe at the bottom of the carbs were the fuel goes in
Jacko
[Edited on 28/11/08 by jacko]
Wowwwwww... you mean, that I connect pipe for breathing on fuel line ... and tube for connect fuel line I connect on vacuum sensor on engine...
...and engine was running! Im happy that Im still alive
The "F" tube on your photo is only for fresh air too carbs? And pipe which I connect on vacuum sensor is main input for fuel?
How is possible that engine was running?
Thanks gods that I survived!
Im building Tiger Cat E1 Duratec engine
Canada EH!
posted on 28/11/08 at 11:35 PM Reply With Quote
The steering wheel is on the proper side, he is driving an automobile not a BOAT!
mark chandler
posted on 28/11/08 at 11:43 PM Reply With Quote
That does indeed look very wrong, fuel goes in the bottom and the top pipes are vents so leave open.
Vacumn will be sourced from the car side of the butterflies.
Regards Mark
blakep82
posted on 28/11/08 at 11:48 PM Reply With Quote
have you experienced a british summer?
________________________
jacko
posted on 29/11/08 at 10:07 AM Reply With Quote
What modle carbs have you got ie
[ C /B / E mine are E's
Jacko
errrr... haven't a clue. these ones have tps, so good enough for me (i hope, this time lol)
Have you got a photo of your carbs ?
jacko
posted on 29/11/08 at 10:10 AM Reply With Quote
Jacko
Im glad i could help and put you on the right track if it was me i would get a bike fuel pump there the right one for the carbs and cheep on ebay
Graham [ Jacko ]
[Edited on 29/11/08 by jacko]
jacko
posted on 29/11/08 at 02:13 PM Reply With Quote
The pipe you have going to the vacuum sensor as you call it is the sump breather
and a pipe from the breather wants to go to a catch tank but remove the one way valve first
What made you think your pipe would want to go there?
black.viper
posted on 29/11/08 at 09:12 PM Reply With Quote
Thank you guys for ideas... next week I have lot of work :-)
IŽll start with new bracket for VR sensor, change fuel pipe for right place and small upper pipes I let it breathing fresh air (no fuel ) and if every thing will be OK and fuel will not splattering I hope that I will not have to change my new Facet fuel pump... but I will see..
Thank you for this forum and for nice people here!!!
Lot of wishes from Czech republic,
Petr
<<  1    2  >>
