<<  1    2  >>
Author: Subject: underslung exhaust systems
mr henderson
posted on 23/12/08 at 04:22 PM Reply With Quote
2" = 50.8mm
1" = 25.4 mm
25.4 x 25.4 x 3.14 (pi r2) = 2025sq mm
150mm x 10mm = 1500 sq mm
posted on 23/12/08 at 04:45 PM Reply With Quote
True but the area is so large that the gas flow would be quite slow
And that hurts performance as much as back pressure.
edspurrier
posted on 23/12/08 at 06:15 PM Reply With Quote
So a series of narrow cylindrical tubes with an ideal total diameter?
907
posted on 23/12/08 at 08:34 PM Reply With Quote
You would need five 1" pipes to equal a single 2" pipe.
Paul G
sebastiaan
posted on 23/12/08 at 09:06 PM Reply With Quote
I think this is how westfield do their underslung system for the V8:
westy exhaust
a bit ride heigth critical, but not too difficult to knock up.
edspurrier
posted on 23/12/08 at 09:42 PM Reply With Quote
I was thinking more 20 pipes of 11.5mm dia to make a 2 inch up. So have 5 for each cylinder, perhaps, running to a frankly ridiculous collector at the back. Heaven knows what the losses would be. Perhaps you could vary the diameters so each is harmonic for a different engine speed? Might make an interesting noise, even if it did sap all the power away.
The Black Flash
posted on 23/12/08 at 10:47 PM Reply With Quote
Wait and see what happens I reckon...it's under appeal from all the manufacturers so I'm told.
A1
posted on 23/12/08 at 11:05 PM Reply With Quote
fingers crossed the manufacturers win!!!
toes too...
NS Dev
posted on 23/12/08 at 11:30 PM Reply With Quote
kart style sidepods?
C10CoryM
posted on 24/12/08 at 04:17 AM Reply With Quote
Not sure if it helps, but the Donkeyvoort car use rear exit exhaust with covers over the sides.
Anyone have pictures of locosts with rear exit exhaust? I've decided to try and go that route myself as the engine Im using does not have a nice exhaust note.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
bilbo
posted on 24/12/08 at 09:25 AM Reply With Quote
This is what I'm currently thinking. I think I will continue down the traditional line of a side exhuast for now, then box it in like this if I need to. (probably be cunningly designed to fall off on the way home from the test - unless it looks really good for some reason)
At least I've not got big headers to worry about, just a single pipe.
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
ss1turbo
posted on 25/12/08 at 11:24 PM Reply With Quote
a simple calc and the area of a 2 inch pipe is about 19.5 cm sq compared to almost 8 times as much for just a 150mm wide 10mm thick flat pipe meaning the gas is travelling around only 1/8th the speed inside so little in the way of drag…
[Edited on 23/12/08 by Mr Whippy]
I'm having trouble following your maths
Paul G
I think there's a zero gone missing somewhere...15cmx1cm = 15cm2 last time i used a calculator! A 200mmx10mm section would be about the same, dependant on wall thicknesses!
Didn't a factory Westfield of some 90's vintage use twin 1.5" pipes underslung to get round clearance issues?
IIRC its the McLaren SLR which has the exhausts exiting in the front wings, so as not to disturb the flat floor..
Long live RWD...
Simon
posted on 26/12/08 at 02:43 AM Reply With Quote
Iirc the Viper exhausts are housed inside the sills - which I know we don't have, but they wouldn't be difficult to make from F/g or ally. Would suggest wrapping the exhaust all the way down as Clarkson managed to get sill alight.
I think underslung the car would work only if provision was made from the build outset - I only have 5" clearance under the car!
When I was doing the turbos a friend suggested I run the exhausts straight from the turbo outlets and cut them flush with the side panel
Simon
<<  1    2  >>
