RMarine
| posted on 14/7/10 at 05:25 PM |
right i think that i have figure that out i have set it to 200 V ( the sign has a ~ over the V) and i am geting 00.6 when i am cranking. but its still
not starting.....
scudderfish
| posted on 14/7/10 at 05:32 PM |
Is your trigger wheel 36-1 (i.e. it has 35 teeth and a gap)?
Do you have a good 12v feed to the coil pack?
Is the cable between the VR sensor and the EDIS screened?
Is the screen earthed only at one end?
Have you checked for a spark at the plugs?
RMarine
sorry...i am using the fly wheel as the trigger wheel.. sorry for the misunderstanding
scudderfish
| posted on 14/7/10 at 05:37 PM |
Ah, just spotted you're running a Zetec, so whatever is already fitted to the engine is going to be fine. As you are reading 0.6v you are
probably getting a good enough signal from the VR sensor.
For the sake of two minutes, swap the leads on the VR sensor, it foxed me for a while on my car, you never know....
RMarine
| posted on 14/7/10 at 05:47 PM |
Success!!! i know have spark at cyclinder 1 &2 according to the timing light but not 3&4
scudderfish
| posted on 14/7/10 at 05:50 PM |
That sounds like one side of your coil pack isn't firing, and you've not connected the right plug to the right post. If you hold the coil
pack with the three wire plug facing you, 1 & 3 should be connected to one side and 2 & 4 the other.
scudderfish
| posted on 14/7/10 at 06:02 PM |
Incidentally, if you're getting some sparks then it means your sensor is mounted OK, wired correctly, and you haven't completely fried you
EDIS, so it is definitely good progress
RMarine
| posted on 14/7/10 at 06:05 PM |
IT' S ALIVE.....         bloody great. thanks for all your help!!!!!. now i have to get the megajolt working next !!
scudderfish
| posted on 14/7/10 at 06:07 PM |
Fanbloodytastic!
