speedyxjs
posted on 16/12/11 at 04:49 PM |
Jag straight six's regularly go for well under £100 on ebay Easy 200hp plus
froggy
posted on 16/12/11 at 07:57 PM |
Finding a manual box and flywheel for a jag isn't so easy though .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
coyoteboy
posted on 19/12/11 at 07:47 PM |
All alloy is not always lighter, the SR20 all alloy engine is similar weight to 3sge (with cast block and alloy head)...
Indeed, and with the transmission bolted up it seems it's not actually too far off the all alloy Audi V8. I spent a lot of time researching
engine weights and for high power output there's not a lot in it, +-15-20kg among the 300hp easily available contenders. If you want serious
power to weight for the engine alone then look down the bike engine route, but it's not cheap. I threw together a big spreadsheet of costs,
powers and weights and ended up looking like there'd be about 100kg max to min going from a beasty V8 to a tiny 1 litre BEC, when you consider
the required additional parts.
