posted on 27/8/13 at 10:11 AM |
Hi Daniel,
Sounds like it will be a ferocious little car when built.
I might have missed it above, but what engine are you planning to use?
mcerd1
posted on 27/8/13 at 03:04 PM |
quote: Originally posted by jeffw
this is what I did to a Type 9 with 260 ft lb
ouch
can I ask why your not using a T5 ? (ratio's ?)
[Edited on 27/8/2013 by mcerd1]
jeffw
posted on 27/8/13 at 05:08 PM |
I've always had the same BGH Type 9 in the car so when it went bang it seemed sensible to get it fixed (Alloy cased E8s have some value after
all). A T5 is a possibility but I would be much more likely to so sequential for the next box (Elite IL300, Quaife 60G etc)
TurboWood
posted on 28/8/13 at 01:04 AM |
Hi Daniel,
I sure hope it's a beast! I'm planning to use the GM LDK (called LNF in the US) 2L ecotec engine. 290hp with a factory tune and easily
more with some fiddling.
Daniel
*edit*
ecotec (GM), not ecoboost (ford)
[Edited on 29/8/13 by TurboWood]
mcerd1
posted on 28/8/13 at 07:30 AM |
....Alloy cased E8s have some value after all....
yeah, I've got a bargain iron cased E8 waiting to go into mine just now and I know how much that cost
the alloy case alone must have set you back a bit, do you know the total weight of your E8 ?
TurboWood
posted on 29/8/13 at 11:08 AM |
You guys make me thing I have to bit the bullet and get the quaife. I just wish I could find someone that has used it to offer some opinions.
Daniel
jeffw
posted on 29/8/13 at 11:57 AM |
Well not exactly but.....I tried to pick up the Iron Type 9 and struggled to lift it (as in....this is bloody heavy). The Alloy case one you can pick
up easily and carry under one arm.
mcerd1
posted on 29/8/13 at 12:07 PM |
opinions.
might be worth having a look over on the westfield / caterham forums - I know quite a few of them use the quaife boxes
jeffw
posted on 29/8/13 at 01:27 PM |
It is quite common to use the dog box version (57G ?) in sprinting with the Westfield guys, those that don't use the 60G of course.
