mark chandler
| posted on 5/1/14 at 09:03 AM |
You would have to lose that big black box and replace with something like a Nissan pulsar plenum then build an adaptor to exit the air from the
charger along the new plenum to do it properly. Unless the existing plenum is used to secure the charger I do not see why it's an engine out
job?
Regards Mark
Sierra
| posted on 5/1/14 at 10:41 AM |
I only say engine out as you can't get to half the bolts you need to remove the inlet/plenum. The charger is bolted directly to th plenum and
again half the bolts are unexcessable.
jeffw
| posted on 5/1/14 at 11:32 AM |
Somebody has obviously spent a lot of time on building it this way. I assume the M45 is directly connected to the Plenum? So, potentially, you could
turn the M45 upside down, exit from supercharger into a intercooler/chargecooler in the nose, intercooler/chargercooler into a Pulsar GTiR Plenum with
the thottle body inbetween the intercooler and plenum.
This would give you the best result.
Sierra
| posted on 5/1/14 at 11:42 AM |
Yeah a lot of time has been spent as it does look very well made, the m45 is bolted directly to the bottom of the plenum then the inlet of m45 has a
section also going into the plenum and a second section for tb and air filter.
As you say flipping it would work but after looking yesterday the steering shaft is literally mm's from the bottom of m45 already so physically
no room to flip and fit adapters.
Unless of course a new plenum was made to sit higher up which in turn would give the m45 a little more room and may fit flipped around.
Is the gtir plenum a direct fit or does it need welding onto a ford inlet?
jeffw
| posted on 5/1/14 at 12:04 PM |
You could certainly get an adaptor made (Flak Monkey on here did mine)
Have a look through this for ideas
http://www.locostbuilders.co.uk/viewthread.php?tid=165764
[Edited on 5/1/14 by jeffw]
Sierra
| posted on 5/1/14 at 12:08 PM |
Ok thanks I'm going to have to work out the cost all in as I can imagine it will all add up to a lot.
Then work out whether it's really worth it at the minute. Obviously have to get someone to check the inlet temps for me first before buying
anything as they might not be as bad as I think at only 6psi. But saying that the inlet does get really really hot after a run so probably way to
high.
beaver34
| posted on 5/1/14 at 12:52 PM |
I thinkit would be worth measuring your inlet temps for now, you can see what they are in the omex 500 I presume, I run the later 600 and can log
mine.
If you have a base to work from you can see how bad the situation is or not
