Nickp
posted on 26/11/18 at 06:45 PM |
whey are you using 3400 as a speed?
the standard speeds should be 4800, or for later units 38400
I am sending you a pm/u2u with link to unzipped v3 sw
I've tried 4800 as well with the same result. I also tried with no speed specified at all, same result. It seems that it can't open the
serial port to start with which I don't really understand.
I'm aiming to try and update it to 2.5.0 controller firmware which would then allow me to use V3.0 configuration SW, as below-
V 2.5 firmware / V3.0 configuration software
PC Configuration/Tuning software, version 3.0.0
Controller Firmware, version 2.5.0 (right-click / save)
rf900rush
posted on 26/11/18 at 09:26 PM |
I have seen some computers (Laptops) that have different com port hardware.
What might be worth checking, is the com port, what I would call a real one.
This can be checked in the device manager.
>ports(COM & LPT)
communication Port (COM1)
Resources should be something like I/O Range 03F8 - 03FF.
Nickp
posted on 26/11/18 at 09:30 PM |
>ports(COM & LPT)
Yes, that's what mine says.
Did the loopback test to Hyperterminal earlier to prove port and lead again, all OK.
Nickp
posted on 3/12/18 at 07:26 PM |
I've had to draw the line on this one as I'm still unable to connect. A mate who's good with this sort of stuff also had a go with
his laptop and lead with no success. The ebay seller has eventually agreed to a partial refund as I kept the EDIs unit.
I've got a working unit from AdrianH off here and should have it all up and running soon
