<<  1    2  >>
Author: Subject: megajolt - no spark
bikecarbfred
posted on 14/1/19 at 06:59 AM Reply With Quote
We all check that coil pack is getting 12V.
But need to always check if it is getting 12V when you actually crank the engine.
I was getting 12V when ignition turned on leading me to believe wiring was correct.
But when cranking the engine it dropped to 0V.
I had plugged the power cable into the wrong accessory fuse socket.
<<  1    2  >>
