owelly
posted on 8/10/05 at 02:20 PM |
If the mainshaft is not bang-on in-line, the 'box will want to jump out of gear. And don't forget, the spigot bearing is only turning when
you have the clutch pressed.
Like Trev Borg said, if you need any dimentions, piccies, solutions etc, feel free to get in touch.
http://www.ppcmag.co.uk
posted on 8/10/05 at 04:40 PM |
If the first motion shaft is not cental with the bell housing/spigot bearing the first thing likely to break is the clutch center plate. Found out the
hard way one winters night a few years ago when the car I was driving broke down. No signs of jumping out of gear or noises . later found out the bell
housing had cracked due to severe clutch judder, bell housing had been welded but not aligned.Hope ypu get it sorted, lovely engine when running nice.
Liam
posted on 8/10/05 at 11:18 PM |
quote: Originally posted by NS Dev
did it get into the back of the fiat? Any pics? What was it used for? We did a similar thing with a Nova for rallying, but not a v6!
It's like the 164 subframe was designed to fit in a cinquecento!! The front member of the subframe butts right up to a structural member in the
cinq floor, and the back of the 164 frame just fits inside the rear bumper of the cinq. 164 struts just fit inside the cinq bodywork, just underneath
the rear windows. Wheel arches will need to be about 6" wider each side!
Being built as a super cheap track beast, but project cinq is on hold as my mate is in new zealand. Subframe is mounted in the cinq and waiting for
some tubular structure to be added (as there is no structure at all in the back of a cinq!) This rear structure will flow into a full cage.
Unfortunately not got any decent pics. I might need my engine crane soon for the locost so i'll pop down the cinq garage and get it and take
some photos.
Liam
Afraid this is the best pic i've got at the mo!!
NS Dev
posted on 9/10/05 at 09:37 PM |
some photos.
Liam
heh heh!!!!
Now that's what I call a proper budget project!!!
Giving me ideas now!!
G.Man
posted on 10/10/05 at 02:10 PM |
quote: Originally posted by Johnmor
Both the GTV and the 75 and 155 had the clutch and the gearbox in the rear transaxle, provided better balance but only a prop shaft ran from the
engine.
There are only a few Alfas with traditional rear wheel drive system.
Spider (65-93)
Alfa 6
Giulia
Bertone and
Berlina
Almost all are pre 80s
Home engineering looks the only way!!!
Yup knew about that, thought it would still be possible with some "adjustment" to the rear diff mounting area...
Opinions are like backsides..
owelly
posted on 10/10/05 at 09:17 PM |
Job done!!
Johnmor
posted on 10/10/05 at 09:43 PM |
WELL DONE
looks good, very neat for the tranmission tunnell.
Can you run the engine on the bench or will you wait untill it in the car?
G.Man
posted on 11/10/05 at 06:40 AM |
Nice
Trev Borg
posted on 11/10/05 at 05:29 PM |
I don't know about nice!!!!!!
It looks like you bolted the gearbox to the engine with an old biscuit tin.
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
owelly
posted on 11/10/05 at 10:08 PM |
I have built a stand to bench run the engine but as I am still waiting for an exclusive, hand crafted, one-off, special tuning wiring loom, the
engine/'box has found its way into the car. i just need to cobble some engine mounts, extend the reversed air plenum runners and wait for the
loom........
owelly
posted on 11/10/05 at 10:09 PM |
And reinforce the biccy tin with Muller Fruit Corner tubs.
Trev Borg
posted on 12/10/05 at 09:43 AM |
Ok
point taken
I will have the loom at house by tonight hopefully. All labled up to avoid colour blind freaks getting them wrong
And the engine crane if i can arsed
owelly
posted on 12/10/05 at 08:53 PM |
I was expecting a wiring loom and an engine crane but someone has dumped some scrap and a pile of wires in my yard!!!( Cheers matey)
I might even have a run out of it before too long ('Lil legs permitting!)
owelly
posted on 15/1/06 at 03:47 PM |
And it does run!!!
locost_bryan
posted on 16/1/06 at 01:13 AM |
Do you have the dimensions and weight of the Alfa V6?
1) Length from pulley to flywheel
2) Width
3) Height sump to highest point
4) Height bottom of block to highest point
5) Weight as removed from donor
Anything that pokes outside these dimensions? Headrers? Dizzy?
Can add to my list for reference - not many Alfas sold down here, but useful to compare to the Jap alloy V6's (Mitsi FTO, Mazda MX6, etc)
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Johnmor
posted on 16/1/06 at 07:50 AM |
Search for thread "V6 dimensions"
The sump very much depends on the car that it is removed from. Rear wheel drive sump is not as deep as front wheel drive versions.
How is Auckland, worked at the building of the TVNZ HQ near Nelson St in1988, had a bal.!!
locost_bryan
posted on 17/1/06 at 02:22 AM |
Lovely sunny day today - about 26C - great day for getting out in a Locost!
Auckland's got bigger, taller, more congested in the last 17 years. Big upgrades to the waterfront since the Americas Cup, thousands more
apartments, more restaurants and bars and nightclubs, better public transport, lots of motorway building right now.
Check out http://www.aucklandcity.govt.nz/ for the latest....
Bryan Miller
Auckland NZ
locost_bryan
posted on 17/1/06 at 02:45 AM |
Thanks.
Alfa V6 540/640/710 w/h/l (610w incl headers)
Mazda KL V6 2.5 200bhp 675/640/620
... so the Mazda's shorter but wider.
Hard to compare weights :-
Alfa 138kg "short" motor excluding manifolds and ancillaries
Mazda 176kg "long" motor including manifolds and ancillaries
Bryan Miller
Auckland NZ
Johnmor
posted on 17/1/06 at 07:02 AM |
Alfa V6
The Alfa is a 60 degree V6 , most are 90, so that makes it a little taller and less wide, but the stoke is vey short which means it revs well(24v goes
to 7300 easy). I would think an Alfa v6 would be a rare comodity in NZ, i know things have changed but when I was there you would have needed a
mortgage for a car like that.
Over here they get thrown away. the big problem is attaching a gearbox, the only option realy is to fabricate some form of conversion plate and use a
FWD bellhousing. Or make your own Bellhousing.
Post some pics of the sunmmer weather and your car to cheer us all up.
