MikeR
| posted on 11/12/05 at 04:09 PM |
they look just the job. If you want to spend more money i'm think Demon do one that will screw into the top of your tank so no need to have
rubber hanging around.
RazMan
| posted on 11/12/05 at 07:20 PM |
The Harris Performance ones look really pretty but they are only a simple one way valve. This will allow air in (to stop tank implosion) but
prevent expansion pressure escaping. So on a hot day, when your tank is roasting, won't there be a risk of vapour pressure leaking through a
weak pipe union or similar..... or am I just paranoid?
The ThinkAuto ones are a little more sophisticated (and more expensive at £25 each!)
Quote" A range of fuel tank valves that allows 1)air in to replace fuel used, 2) air out due to heat expansion. 3) a positive shut off to
prevent fuel escape, due to splashing or even roll over. This is achieved by a two ball system, one hollow plastic, one solid steel."
I'm looking into these soon as I have twin tanks to worry about. The TRL7 (not shown) is for in line fitting into ¼” bore hose and must be
mounted vertically.
Probably the dogs danglies but at a cost!
[Edited on 11-12-05 by RazMan]
Raz
tks
| posted on 11/12/05 at 07:39 PM |
mhh
for filling up it isn't necessary because you have the cap taken of the tank..
sow whats the point??
its only for vacuum... well i have an loackable filler/aero cap..and i'm sure its leaking...enough sow no breather fitted...
Tks
RazMan
| posted on 11/12/05 at 07:55 PM |
Here's more bedtime reading from the Newton Products site - I think they manufacture the valves.
linky
Raz
bob
| posted on 11/12/05 at 07:57 PM |
I managed to get mine with a little discount from thinkauto,i just mentioned this site and locostcar club.
I'm pretty sure is was about £22 or less,i did pick up though.
The harris ones do seem a keen price though.
NS Dev
| posted on 11/12/05 at 11:43 PM |
quote: Originally posted by MikeR
quote: Originally posted by Avoneer
This is nothing to do with the car rolling over - that is something else.
This is to with not creating a vacuum in the tank so it doesn't collapse.
Pat...
No Pat, this is everything to do with being in an accident. You need a vent in your tank to stop the vacum. What i'm saying is make sure your
vent is safe. Think not just for stopping the vacum but when you're in an accident. Those with lines that run up to the roll bar and back down
are not safe! What i'm doing is fitting a vent from stoneleigh. Its not perfect as its going to be attached via a small rubber tube which should
(hopefully) be fireproof.
I find it strange but the rules on building road cars are now more strict than race cars in many areas. This is one of them.
Mike, I just use (on the grasser) a piece of copper brake line, from the very top of the tank, looped around the tank and down to below the bottom of
the tank, near ground level.
Car right way up, fuel can't get out, car upside down.......fuel can't get out...........car on side.......fuel can't get out.
Simple, with the pipe looped around the tank, whichever way up the car lands, the fuel has to flow uphill, so it won't leak out.
NS Dev
| posted on 11/12/05 at 11:46 PM |
PS.............to those using "PROPER" vent valves.......................................put some fuel in the tank and turn it upside
down...............................I got a shock when I saw the fuel pouring out of the - fairly expensive - vent valve............hence the looped
kunifer pipe on the grasser!
[Edited on 11/12/05 by NS Dev]
Viper
| posted on 12/12/05 at 07:29 AM |
thats just how we do it on circuit sallons...
MikeR
| posted on 12/12/05 at 06:46 PM |
Aaah, but, what if you're rolling down a REALLY long hill, every time the car does a complete revolution a small amount of fuel will leak out
:p
(ok ok, good solution! i'd also squash the end of the tube so only a limited hole existed cause i'm like that).
tks
| posted on 12/12/05 at 08:37 PM |
mhhh
but in fact you make then an connection to your tank...
and then the problem arises that you car needs to smell to petrol, because out of that tiny hole is comeing tank vapoour...
i thought the normal car industie had some filters for it?
i think the best thing we can do is build an spring powered undo vavle..
should be easy! sow locost guys come up with something thats shutdown when you don't use the car!
Tks
tks
| posted on 12/12/05 at 08:38 PM |
Something like this,
when the sucking force wins from the spring it untapers the little hole sow it will suck air in, then the spring will win and it will be closed
again..
in an uppside down case, the weight will close the valve anyway...
MikeR
| posted on 12/12/05 at 08:46 PM |
if we're being acurate
All flaps / holes in the fuel tank should have a spring mechanism on them so if the tank is upside down the flap stops the fuel rushing out.
something else "you're all going to die" mate couldn't believe we didn't have to have!
NS Dev
| posted on 13/12/05 at 09:17 AM |
:p
Yep, a tad would come out in that situation!
Yes, squash the end up as well a fair bit, certainly would not do any harm!
| posted on 13/12/05 at 11:48 AM |
Mate does fuel systems for a living.
so what does your mate say we should do?
MikeR
| posted on 13/12/05 at 08:42 PM |
Stop playing at making cars would probably be high on the list, followed by keeping that death trap away from him.
The problem is, he has to go through more regulations than you'd believe. Each there for a good reason. We don't.
Basically, get a strong tank. Put flaps on all openings so fuel can't flow out if the car is upside down/ on its side. Remove all rubber from
the system & use something fireproof. Sacrifice a chicken and pray to your favourite deity.
He was explaining what once company had had to do for Rolls Royce. Because of emissions rules, you can only emit so many hydrocarbons a day. With the
rollers having such big rubber tyres they give off "loads" (relative term) of hydrocarbons. The fuel system therefore had to be near zero
emissions to save the environment.
[cough] mpg on a roller? [cough]
| posted on 13/12/05 at 10:34 PM |
tks, surely the pair of bike valves would be just like the sprung devices you drew? These probably wouldnt leak when immersed, but a small bit of
pressure either way would open one or the other. You need one to let air out, because the air in your tank will expand significantly on a hot day,
especially in a garage, maybe bending the tank.
Smartripper
| posted on 15/12/05 at 08:24 PM |
Hello,
I'am using some from a shipyard, they are waterproof and from alu.
They where only 4,50 euro. with antiroll membraam.
Greeting Daniel
carlgeldard
| posted on 16/12/05 at 12:45 PM |
Sorry for being a bit behind but I got mine from here!!!!!!!!!!!
Carl
