Johnmor
posted on 24/2/06 at 06:40 PM |
Radiator
Just got hold of a rad from a Volvo 740, .
Looks as if it might fit ok, may have to tilt it a bit to clear the rack with bottom hose but looks ok.
Size 550mm wide 430mm high.
Alloy with remote expansion tank.
posted on 24/2/06 at 06:44 PM |
Measure your radiator mounting area and your top and bottom hose diameters , positions and bleed hoses. check your local Yellow pages for radiator
specialists, take your measurements and have a chat with them , they may have an off the shelf unit or be able to make a one off for you HTH
Tricky Dave
posted on 2/3/06 at 01:08 PM |
Found one!
Serck in Manchester are supplying a radiator out of a Land Rover 2.5 TD which is 480 (plus tanks) x 350 (if I remember right - definitely fits
anyway!) with 4 cores for £125. Bingo!
Cheers for the help.
