<<  1    2  >>
Author: Subject: Engine ideas
akumabito
posted on 13/5/08 at 10:30 PM Reply With Quote
Rocky Road sells kits to mate VW diesel engines (both NA as well as turbo) to the Samurai transmission. Those engiens are cheap, and lots of options for more power, too.
Besides, with the current exchange rate, the RR adapters are a pretty good deal!
http://www.rocky-road.com/diesel.html
posted on 14/5/08 at 09:37 AM Reply With Quote
Originally posted by dunk
NS Dev. The problem is the sump clearance with the vx engines i would have to go SPOA and i dont want to do that to my truck. A mate of mine had a 2.0 vx Carlton engine in his Sj and it used to rip the t-box out for fun.
You don't have to use the original sump though, you can get low profile sumps for these engines.
NS Dev
posted on 14/5/08 at 05:18 PM Reply With Quote
yep, and they are only steel anyway so dead easy to "adjust" with the mig welder!
mad4x4
posted on 18/5/08 at 12:44 PM Reply With Quote
Originally posted by coozer
Right then, here we go... how about a Corsa 1.5TD or Astra 1.7TDi??
Its a Isuzu engine, small and gives good torque and power, very easy to fiddle with the pump and get it flying.
Isuzu 2.8TD engine will give you stupid amounts of Powers in a Zook and is small. Don;t know what gearbox you'd use. You should be able to make a converison.
I had one in a 90 at Drumclog and pulled a 7.5Tonenr with a Rangier (6x6) and Caravan out of the site.
Vaxuhall Cartlon 1.8 or 2l used to be the Zook converion for the Sj's used to drop engine and G/Box in and marry to the SJ Transfer box.
Scot's do it better in Kilts.
mad4x4
posted on 18/5/08 at 12:47 PM Reply With Quote
Hi Dunk, pardon my stupidity but whats "SPOA"??
Can I have a guess ?
Sump Pan Over Axle ?
Nah, can't be, surely...
SPOA - is a acronym for
Spring over Axle Conversion and was popular on the Old SJ's as the axles used to be mounted ontop of the springs. Buy putting the Axle under the spring you gained about 5" ride hight
<<  1    2  >>
