Author: Subject: Mounting Polo Radiator
mikeb
posted on 7/11/08 at 03:58 PM Reply With Quote
Last time I looked at my mk2 polo rad. There seemed to be four mounting holes.
These were just holes in the plastic and would need self tappers, not 100% convinced, anyone got any pics of a similar install?
Mike
martinq357
posted on 7/11/08 at 04:06 PM Reply With Quote
There were two plastic lugs on the bottom of mine so I located these rubber gromits, mounted in a 3mm ally plate.
I used the mounting holes for the fan on one side and as bracing to the chassis on the other side.
I'll try to post pictures tomorrow.
HTH
Martin.
SyKaTurbo
posted on 7/11/08 at 04:10 PM Reply With Quote
You can used bolt to drive into the plastic mounting lugs.
Bob has some good pics in his archive. I did mine this way also
http://www.locostbuilders.co.uk/photos.php?action=gal&user=bob&folder=zetec%20water
jollygreengiant
posted on 7/11/08 at 04:23 PM Reply With Quote
I made up a mounting plate that bolts to the rad then bolts to the car,
Rad mounting plate from bacl/bottom
There are a few other photo's in my archive. Can't say that its a tried & trusted way as I'm not on the road yet.
adithorp
posted on 7/11/08 at 05:34 PM Reply With Quote
I mounted mine by the 4 holes. Just screwed M5 (I think) set screws in. Check the depth first and screw length and leave a bit to spare. Screw cuts its own thread.
adrian
http://jpsc.org.uk/forum/
martin1973
posted on 7/11/08 at 05:36 PM Reply With Quote
my westy is just mounted on the 4 plastic lugs threaded with m5 allen bolts,
no problems so far.
martin
paulf
posted on 7/11/08 at 07:08 PM Reply With Quote
I used the 2 pins on the bottom into brackets on the chassis to take the weight and then fitted 2 brackets to the top tapped holes and chassis using large self taps.
Paul
IDONTBELEIVEIT
posted on 7/11/08 at 09:55 PM Reply With Quote
you can just see the top mounting a piece of folded ali and bottom mount welded to chassis Rescued attachment DSCN1877.JPG
Are We There Yet, Are We There Yet!!!!
