posted on 12/11/08 at 11:58 PM |
Blacktop Cambelt??
I am getting my ST170 engine ready for the car and am wondering if the cambelt is the same as all other blacktops? And can I expect to have to buy a
kit with idlers the same as a silvertop engine
Anyway its coming along now and heres how I've run the alternator and idler
stevebubs
posted on 13/11/08 at 12:15 AM |
If it's got plastic idlers, I'd replace them as a matter of course....
MikeR
posted on 13/11/08 at 12:24 AM |
i've never done anything on a black top - but i'm curious why you don't get a lot shorter belt for the alternator and completely
take out the top wheel (which i assume is an idler pully).
posted on 13/11/08 at 08:15 AM |
Water pump needs to run anticlockwise so an idler is needed. Want to keep the water pump standard and as henry intended.
r1_pete
posted on 13/11/08 at 08:31 AM |
Its the same layout as my blacktop, the idlers are a service item the manual does specify replacement, expecsive on the face of it, but cheaper than
16 Valves, a couple of pistons, head work......
Rgds.
Pete.
stevebubs
posted on 13/11/08 at 10:09 AM |
Is that auxiliary idler a standard item on the ST170? If not, where did it come from?
posted on 13/11/08 at 11:33 AM |
Its the ribbed one on the adjuster next to the alternator on the original setup. All I've done is swap the wheel for the smooth one thats
elsewhere on the focus serpentine belt. The other one is steel though and this one is plastic but as its come off the original setup it should be OK..
Yes??
[Edited on 13/11/08 by coozer]
focijohn
posted on 13/11/08 at 06:39 PM |
looks the same as my focus. 70 odd for a kit and for piece of mind and like r1_pete said cheaper than head and valves etc
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
