Author: Subject: Coil Pack
wrigglypig
posted on 13/11/08 at 11:42 PM Reply With Quote
Coil Pack
Does anyone have any advice or guidance on which coil pack to use with a 1.8 cvh with megajolt?? I have one from a BMW which works but I dont know what the connections are anyway, is there one thats better to use than the rest ? or does anyone have a spare for sale? IDEAS???? Kev
blakep82
posted on 14/11/08 at 12:00 AM Reply With Quote
ford ones are the easiest i think. all the wiring diagrams i've ever seen are for the ford ones i think, assuming its the edis you're using
________________________
mediabloke
posted on 14/11/08 at 12:41 AM Reply With Quote
I bought a new, boxed, Ford early-design coil (made by QEH, IIRC) for £30 in March this year.
I realised afterwards that the later design would be a better fit for my Vauxhall leads.
If it's of any use to you, I'd be happy to sell it - it's never been used.
mcerd1
posted on 14/11/08 at 09:05 AM Reply With Quote
easy - the early ford coilpack is the one that was fitted to loads of CVH's in the factory
so the leads you'd need would be the standard 1.3 / 1.6 ones from an early 90's escort/ fiesta (these also suit all the older engines that don't have rubber boots on the plug leads)
[Edited on 14/11/08 by mcerd1]
r1_pete
posted on 14/11/08 at 09:15 AM Reply With Quote
Don't forget you need the EDIS unit too, all the megajolt does is control advance and retard depending on engine conditions.
ss1turbo
posted on 14/11/08 at 11:58 PM Reply With Quote
If using the EDIS unit to provide the coil driving (and Megajolt to change the timing), then you need to use the Ford coil pack - as its electrical characteristics are matched to the EDIS unit. If your HT leads are not long enough, custom length ones are availble these days with Ford coil pack ends easily - I think Magencor do them.
Long live RWD...
