albertz
posted on 20/1/04 at 09:10 AM |
Type 9 Conversion to 4AGE
Could someone please tell me what is required to use a Ford Type 9 gearbox on a Toyota 4AGE engine?
I know there is a modified bellhousing available, but does the input shaft match? if not how do i get around that problem?
Also do i need to change the clutch and everything else that is associated with it?
posted on 20/1/04 at 10:15 AM |
Ablertz,
check raw engineering's website.
They specialise in the 4AGE engine and can supply all the bits required for a type 9 conversion.
Nick
paulbeyer
posted on 20/1/04 at 10:53 PM |
I got my bits from Raw Engineering. Bell housing, bolt set, spigot bearing, clutch kit to mate ford gear box input shaft and Toyota flywheel and
thrust bearing. I also got their engine mounts and rubbers at the same time. It's not cheap but Hicost helped me to pressurise Mel at Raw to do
me a cash deal at Stoneleigh. Mel is a helpful bloke he also gave me a late model plenum that I was able to cut down and get tigged and a couple of
engine gaskets I was having trouble getting hold of.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
