Author: Subject: Polo Rad Blanking
Pdlewis
posted on 20/11/08 at 10:13 PM Reply With Quote
Polo Rad Blanking
Anyone know what can be used / where i can get somthing to blank the thermostat take off on a MK1 polo rad?
Build Photo Album
Updated 05/02/2009
Dangle_kt
posted on 20/11/08 at 10:19 PM Reply With Quote
You could always buy a thermostat switch, I think they are about £3 on ebay.
mad-butcher
posted on 20/11/08 at 10:20 PM Reply With Quote
If you mean the little pipe at the top, short length of pipe with a bolt stuffed in it, or you could tap it and put a bolt in
jambo
posted on 20/11/08 at 10:45 PM Reply With Quote
got the switch from mnr
adithorp
If you mean the rad fan switch hole then u2u me your address and I'll stick a plug in the post.
adrian
http://jpsc.org.uk/forum/
posted on 21/11/08 at 08:44 AM Reply With Quote
I bought a thermo switch and wired it in parallel with the one on the thermostat housing - the fan comes on if either switch operates.
smart51
posted on 21/11/08 at 09:30 AM Reply With Quote
I tapped the little pipe at the top and put an M5 bolt in it. Handy for bleeding the radiator when doing a coolant change.
Pdlewis
posted on 21/11/08 at 09:47 AM Reply With Quote
Cheers guys got a fan switch blank sorted and seems like tapping the outlet is an excelent idea i was wondering how to get air out the system
Build Photo Album
Updated 05/02/2009
TimC
posted on 21/11/08 at 02:05 PM Reply With Quote
Is this definetely not needed? I have it tee'd into the hose that runs from the thermostat itself to the header. However, it's a bit untidy and has sprung a leek, plus it makes nose-cone removal a bit tough. If I can get shot of it, I will.
TimC
posted on 23/11/08 at 08:22 PM Reply With Quote
Anyone?
