albertz
posted on 21/1/04 at 01:35 PM |
Sierra Clutches
Can someone tell me if there is a standard Sierra clutch which is 200mm diameter, has a 1" shaft and 23 splines?
It is for fitting into my toyota housing to mate the Ford type 9 box onto my Toyota 4AGE engine.
Any help appreciated.
Cheers.
dozracing
posted on 21/1/04 at 01:58 PM |
Try asking Dreckly via u2u he should be able to help.
Kind regards,
Darren
bazwaz
posted on 21/1/04 at 05:24 PM |
I had a similar problem when mating up my Vauxhall to type 9. If you go to your local motor factors he will have a book listing all the friction plate
sizes for all the different Ford applications.
TL
posted on 23/1/04 at 01:06 PM |
look on www.qha.com where you will find the dimensions you are looking for
Terry
Stu16v
posted on 24/1/04 at 06:42 PM |
Sierra 2.3 diesel......
givemethebighammer
posted on 24/1/04 at 08:02 PM |
Couldn't see a 200mm one but here is the QH clutch book so you may well find another one that meets your requirements.
albertz
posted on 25/1/04 at 04:13 PM |
Thanks guys for the help. Appreciated.
beaufort
posted on 26/1/04 at 07:04 AM |
There are a few available, road, race, heavy duty etc, bolt straight in with the 4AGE to Ford type9 bellhousing, 3.5 kg steel flywheel manufactured
with ring gear goes well too.
