madteg
posted on 25/11/08 at 10:10 PM |
Twin engined BEC
Has anybody fitted two engines side by side onto rear axle. If so have you any pictures as i am building one, need more ideas. Thanks.
DIY Si
posted on 25/11/08 at 10:15 PM |
Speak to the bloke building the furoure kit. His first is twin BEC.
Sun Tzu, The Art of War
GeorgeM
posted on 25/11/08 at 10:18 PM |
Russ Bost
bigrich
fuore f1 of Russ Bost has this set up i think or what about the autograss cars that chain drive both engines to a common shaft then to the rear wheels
PAUL FISHER
posted on 25/11/08 at 10:24 PM |
Froggy on here has a twin tl1000 kitten van,converted by Martin Keenan,nice bit of kit
posted on 25/11/08 at 10:48 PM |
Z cars have done it tons of times. Reverse box with two inputs and low and high ratios!
russbost
posted on 25/11/08 at 10:50 PM |
Nah! You'd have to be stupid to do that!
Yes that's me! 2 x Kawasaki ZX10 (the old engine) side by side, no diff, LH engine drives NSR wheel, RH engine drives OSR wheel - works a treat
but the engineering is a bit tight unless you have loads of space. 274BHP in about 600kgs goes quite well tho'!
There's some pics on the website www.furorecars.co.uk or go to the links page & follow links to my old sites, more pictures there.
MikeR
posted on 25/11/08 at 11:01 PM |
NS Dev is doing the same on a fiat 500 grasser. It uses a solid rear axle (ie no diff).
gingerprince
posted on 26/11/08 at 10:50 AM |
Curious how you got that road legal. I though you couldn't have 2 engines driving 2 separate wheels on the same axle by law? They had to
either feed separately the front and back axle or be a common feed to a single axle? Unless my understanding is wrong...
froggy
posted on 26/11/08 at 12:59 PM |
still fettling mine, the hard bit is getting the engines to work togehter on part load if you go for an autograss set up with both engines turning a
shared shaft . i think the z cars way with a drive box allows to the engines to give a bit when under part throttle but i also think z cars use a
drive box for packaging reasons as one engine sits behind the other in their twin r1 mini. using a pair of twins has added 5" to my wheelbase
and puts the weight in the middle of the car .using a pair of 4cyl engines grasser style would mean a very long shared shaft and possibly some
vibration issues . on the plus side it gets rid of all the bec drawbacks with good torque road car gearing i.e 80mph cruising and all the bec good
points ,loads of revs sequential box etc. downside is single figure fuel consumption, one engine used to manage around 15mpg so with both running i
might manage around 10
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
russbost
posted on 26/11/08 at 01:40 PM |
"Curious how you got that road legal. I though you couldn't have 2 engines driving 2 separate wheels on the same axle by law? They had to
either feed separately the front and back axle or be a common feed to a single axle? Unless my understanding is wrong..."
This appears to be a common misconception, they did give me some grief at SVA, but had to back down after I spoke to some of the highups who said
there was nothing against it in the regs - I offered to install a cutout switch on one engine in order that i could demonstrate it didn't affect
the driveability with one engine driving & the other not, they agreed to this & we drove around the SVA station with the tester driving it
& me cutting the engine out! It then passed
So far as I am aware there is nothing in any regs, construction & use etc that forbids engines driving separate axles - didn't Top Gear do a
"push me pull you" which could be driven from opposite ends of the car - although of course that never had both engines driving at the
same time.
froggy
posted on 26/11/08 at 04:30 PM |
are you calling me stupid??
IDONTBELEIVEIT
posted on 26/11/08 at 05:37 PM |
nice man
Are We There Yet, Are We There Yet!!!!
russbost
posted on 26/11/08 at 11:23 PM |
"are you calling me stupid?? "
No I was calling myself stupid (or insane, nuts, several cans short of a six pack)
However if the cap fits you slap it on yer 'ed!
