Author: Subject: V8 Exhaust... Again!
posted on 29/11/08 at 01:35 PM Reply With Quote
Right... getting to that stage!
The new plan is to use both the OEM manifolds (1.5 inch pipes to 2.5 inch collector) - a short 2.5 inch link pipe for each (no cat) - and then 2 back boxes.
What considerations should I make in relation to selecting the 2 back boxes?
Is it safe to assume that any box with a 2.5 inch inlet will be a safe enough bet?
jacko
posted on 29/11/08 at 01:58 PM Reply With Quote
I may be wrong but i think r1 can's have 2 1/2ins pipes going in
it may help you
v8kid
posted on 29/11/08 at 02:42 PM Reply With Quote
Make sure the back boxes are long enough. I fitted ones about 18" long and the noise measured 109.5dBA thats about 50% above our local track limit. Apparantly the longer the box the more effective it is
mr henderson
posted on 29/11/08 at 03:26 PM Reply With Quote
Are you sure you will be OK not fitting catalysts? How old is that engine (IIRC Audi V8).
John
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 29/11/08 at 03:47 PM Reply With Quote
In discussion with Merlin, they said it is the width (larger diameter) of the silencer box which reduces noise rather than the length.
posted on 29/11/08 at 04:40 PM Reply With Quote
John
Different project John... the RS4 engine is for the road car - I'm using an older V8 for a track car.
v8kid
posted on 29/11/08 at 05:14 PM Reply With Quote
Ah! so it's the width that counts.
I always thought the width altered the frequency and the length was the attenuation.
Merlin should Know I wonder what the ratio is? Twice as wide twice the attenuation?
mr henderson
posted on 29/11/08 at 06:05 PM Reply With Quote
Some interesting stuff here
http://auto.howstuffworks.com/muffler1.htm
John
posted on 29/11/08 at 06:57 PM Reply With Quote
Ta
