Author: Subject: cvh/zetec turbo hybrid thingy
ned
posted on 23/1/04 at 02:35 PM Reply With Quote
I saw this on ebay, yes I know the auction has finished, but thought I'd ask if anyone knows what has been done/what the combinations are. is it a zetec block with a cvh head? if so hows does it work!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2454418936&category=32094
Ned.
beware, I've got yellow skin
ijohnston99
posted on 23/1/04 at 02:37 PM Reply With Quote
Ned,
Zetecinside has some links/info on the conversion. I think it's relatively simple.
Ian
200mph
posted on 23/1/04 at 02:57 PM Reply With Quote
is called a ZVH, cvh head, zetec bottom end. These apparently work very well, seeing as they can be tuned to 450+ bhp, and can propel a fiesta to 170 mph
mmm, would be interesting in a locost
bob
posted on 23/1/04 at 03:21 PM Reply With Quote
Ned
You need to speak with chrisW on this one,i'm sure he knows someting about this method.
I'm also sure its come up before on here too,just needs a bit of searching.
[Edited on 23/1/04 by bob]
garage19
posted on 23/1/04 at 04:23 PM Reply With Quote
People only run the CVH 8 valve head on the zetec so that they can use their stock rs turbo manifolds and management still.
It you can afford new engine management you are better off sticking with the 16 valve head.
Doug.
ned
posted on 23/1/04 at 05:18 PM Reply With Quote
I was just curious as i *thought* the cvh was an ohv engine and the zetec was an ohc engine. am i totally wrong here, as otherwise i couldn't see how they would fit together properly to drive the cams/valves.
this is all out of sheer curiousity btw!
cheers,
Ned.
ok so i did a little search and skim read this site: http://www.jimhearne.co.uk/zvh.htm which explains the conversion. interesting stuff..
cheers all.
[Edited on 23/1/04 by ned]
James
posted on 23/1/04 at 06:20 PM Reply With Quote
So Ned,
You are still alive then!
Where've you been- I hope it was working on the car!
James
thebutler
posted on 23/1/04 at 06:23 PM Reply With Quote
How about just bolting the CVH turbo inlet manifold on a zetec, and lowering compression?
ala
http://www.rsrich.force9.co.uk/zetec-turbo/
James
posted on 23/1/04 at 07:04 PM Reply With Quote
ala
As far as I can tell- these guys have used the CVH head- it's not just a case of turbo-ing the Zetec.
Seems like a wicked idea- I'm a bit dubious about the machining of the flywheel/camshaft like that though!
I'd be interested to know if you could use a different management system to save doing the flywheel stuff- like the Megasquirt for example. I haven't read the Meqsquirt site tho so don't know if you can.
An idea that needs more research I think!
Wicked idea though- cheers for the heads up Ned!
James
[Edited on 23/1/04 by James]
zetec
posted on 23/1/04 at 07:41 PM Reply With Quote
Seen a few people use a sandwich plate between the head and block on the zetec to lower compression, then bolt on RS CVH turbo by redrilling the head as some of the studs are in the wrong place. I don't see why they don't cut off the CVH turbo manifold exhaust flange and weld it onto a zetec exhaust manifold flange save having to drill the head.
James
posted on 24/1/04 at 02:07 AM Reply With Quote
Seems a good 'Lowcost' idea!
I'm curious about how they 'bonded' the plate to the block though?
Guess it wasn't a squidge of sikaflex!
Assuming you can change the management what do you gain from this over using the 16v Zetec head with the turbo chopped and then bolted on?
Or am I missing the point...
James
posted on 24/1/04 at 11:57 AM Reply With Quote
The sandwich plate was used on Xflows years ago to enable flat top pistons to be fitted, you put a head gasket either side of it James.
yours, Pete.
Graceland
posted on 24/1/04 at 02:17 PM Reply With Quote
www.passionford.co.uk
goto forums and have a look round - theres a load of the RS boys using the ZVH conversion on ere, but ti's considered old hat now, and the blacktop zetec is the way forward for big power
James
posted on 24/1/04 at 03:10 PM Reply With Quote
yours, Pete.
They specifically said they weren't going to do it that way- but didn't say why!
James
200mph
posted on 25/1/04 at 04:57 PM Reply With Quote
Ok, have read a thing or two on this, and here's what I make of it..
It's really an upgrade option to the 1.6 CVH engine as found in that old favourite the RS turbo. It offers a relativekly simple capacity upgrade from 1600 cc to anything from 1900-2100cc. The zetec bottom end is also stronger than the CVH, meaning it's relatively safe to get a high compression engine by just cranking up the boost.
The weak point in the combination then becomes the head, at it's flow characteristics are poor in comparison with the 16v zetec. The next stage for the ZVH upgrade then bacomes a stage 2 or 3 head. Of course by the time both of these have been done then price is not too far awya from a custom turbo'd zetec. So I wouldnt do it if I didnt have an RST to start with.
also, with specialised engines now offering a 1900 block the ZVH seems to be less useful.
Personally, I would have the zeetc everytime.
Except I have a crossflow
Mark
