mackie
posted on 24/1/04 at 10:24 AM |
Vauxhall fuel filter?
I'm looking at fuel filters with simple push-n-clip fittings and I suspect that the vauxhall one in this auction:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2455980379&category=10404&rd=1
is just that.
Can anyone confirm that they do indeed have simple pipes over which the hose pushed to be then secured by clips? If so what's the diameter of
the pipes?
Someone suggested before that vauxhall fuel system parts are easy to work with so I thought it was worth seeing.
Mackie.
zetec
posted on 24/1/04 at 02:45 PM |
I used a Omega post pump filter, and yes it comes with nice easy 8mm push on ends. Fine as a post pump injection filter, you will also need a pre pump
filter if using an out of tank injection pump. I used one of those after market "bullet" ones you can clean out, they come with different
inlet/outlet options but cost about £45.
mackie
posted on 24/1/04 at 04:52 PM |
Ouch, £45 is lots. Is their any reason why i couldn't just use another vectra filter before the pump?
zetec
posted on 25/1/04 at 08:16 AM |
Most cars now use a in tank pump. Was advised these were the best way to go for ease of fit and the ability to clean out, probably full of bits of
plastic from the tank, also give a very good flow rate to the pump. I'm sure there are others out there which are just as good.
