AdamR
| posted on 5/12/08 at 02:05 PM |
which spigot bearing?
Does anyone happen to know of a readily available crankshaft spigot bearing with 24mm OD and 15mm ID?
A long shot I know... but I'm led to believe that such a thing exists - possibly a standard Ford item.
rost
| posted on 5/12/08 at 02:08 PM |
SKF sells them, not an automotive part though:
http://www.skf.com/skf/productcatalogue/Forwarder?action=PPP&lang=en&imperial=false&windowName=null&perfid=101047&prodid=1010
471802
their catalogue is here, the search is quite good:
http://www.skf.com/portal/skf/home/products?maincatalogue=1&newlink=first&lang=en
[Edited on 5/12/08 by rost]
Charlie don't surf!
bob
| posted on 5/12/08 at 02:31 PM |
spigot bush/bearing
I've just had a search through a box of spigots i have in the garage, i found one which came up with 24mm OD and 15mmID i will try and find the
manual which seems to have been misplaced but i have a feeling this is a VW/Audi part.
I will bung it in a jiffy bag and post it up to you if you want, if its any good to you just send ale tokens
bob
| posted on 5/12/08 at 02:40 PM |
OK it is a VW part listed for 2.8 V6 and 2.3 VR5 passat.
AdamR
| posted on 5/12/08 at 03:38 PM |
Bob, you're a legend! I'll send you a U2U.
bimbleuk
| posted on 7/12/08 at 07:08 AM |
Now that's a proper spigot bearing! The one I got from RAW for the 4AGE is a 1/3 the depth of that one so I put two in mine for good measure.
