Author: Subject: Zetec timing marks
Slater
posted on 15/12/08 at 11:40 AM Reply With Quote
Zetec timing marks
Hi, where are the timing marks on my Zetec (1994 1.8)?
I have a basic strobe and will need to use timing marks to check EDIS works in limp home mode (10 deg BTDC)once I get the engine started up, then power up the MJLJ and see if it works.
Keith
r1_pete
posted on 15/12/08 at 11:52 AM Reply With Quote
There is a lug cast into the sump at about the 4 o'clock position relative to the pulley.
I've a pdf manual for the silvertop if you want a copy u2u me your email...
Cheers.
Pete.
[Edited on 15/12/08 by r1_pete]
martin1973
posted on 15/12/08 at 01:20 PM Reply With Quote
i marked my own,
aleast that way u know there correct
martin
big_wasa
posted on 15/12/08 at 06:54 PM Reply With Quote
pic
i_froloshki
posted on 30/6/12 at 08:07 PM Reply With Quote
Hi folks,
why does my mark goes to 6 o'clock when the piston is at the upper death point? I made the adjustment when it is on 6 o'clock and the engine runs (on very high revs but i guess it is a MAF problem). I even made the first rub around the block)))) Sould i make it on 5 o'clock?
Yavor
big_wasa
posted on 30/6/12 at 08:57 PM Reply With Quote
Dont use the marks to time the engine use the tools. It will be 100% then.
The cams are set with a 5mm plate in the back of the cams and the crank is set with a pin against the crank web.
The later blacktop doesnt even have that cast mark on the sump.
i_froloshki
posted on 1/7/12 at 07:32 AM Reply With Quote
Thanks Big,
i used the plate for the cams, but do not have the pin for the crank. i will look around to see how it is done and i will check it today)))
Thanks dude, helpful as always)))))
Regards
yavor
big_wasa
posted on 1/7/12 at 09:21 AM Reply With Quote
From memory its the longer of the two pins in this pic.
If you cant get one where you are give me a pm and I will get some dim's if you want to make one.
There is a bolt near the bottom of the block below the breather, exhaust side.
Re your very fast idle, havnt got your iacv the wrong way round have you ? also look for air leaks.
cheers
i_froloshki
posted on 2/7/12 at 06:07 AM Reply With Quote
if you send me some dims it will be great cause i cannot find such bolt in the shops here.
Yavor
tims31
posted on 2/7/12 at 07:45 AM Reply With Quote
You can get the kit from fleabay
Posts to Europe too...Ford & Zetec & Nissan Camshaft Setting Bar Locking Tool | eBay
Build: http://www.martinsfurybuild.co.uk/
