Mr Whippy
| posted on 18/12/08 at 12:59 PM |
fitting cruse control
Hi
I’m wanting to fit cruse control to my bluebird since I’m doing long miles and it’s an auto. I see there are aftermarket ones but has anyone fitted
one and if so was it any good?
I’d originally considered fitting one of a scrap car but decided that it would most likely be too built in to transplant
Ta
| posted on 18/12/08 at 01:43 PM |
locost way would be a hand throttle, as fitted to stationary land rovers use to power generators and machinery - but not necessarily a safe option at
speed!
Mr Whippy
| posted on 18/12/08 at 01:47 PM |
speed!
uh hu that's hardly going to be more relaxing to use is it?
mr henderson
| posted on 18/12/08 at 02:07 PM |
speed!
The real Locost way would be to use a stick with notches cut inthe side, one end goes against the pedal and one of the notches engages in the seat
frame. Change throttle opening by moving the stick to a different notch.
jimgiblett
| posted on 18/12/08 at 02:18 PM |
You might have some speed variance dep[ending on whether you are going uphill, downhill or on the flat.
My 1967 Alfa has a hand throttle but this is more for warming up the engine than cruising.
- Jim
DarrenW
| posted on 18/12/08 at 02:27 PM |
id imagine aftermarket systems wont be too easy to fit either (easier than building a car though). Does bluey have abs? If not i guess you will need
to have some sort of speed sensor and then make up some sort of throttle control. Bit of electronics ion the middle and couple of switches on dash.
Job done.
Do ROV's have cruise control If they do i bet there will soon be one without.
Mr Whippy
| posted on 18/12/08 at 03:10 PM |
Job done.
no the bluey doesn't have ABS, from what I gather the brake light switch disengages it, you have to fit a magnetic speed sensor like many of the
digital dashes need, I was thinking of mounting it to one of the inner cv joints for that. Then there is a vacuum or motor driven throttle cable
pulling device for speed control. Simple enough, I think.
bigrich
| posted on 18/12/08 at 03:36 PM |
thats pretty much it Mr Whippy, fitted one years ago to a Vauxhall Carlton, Sensor worked through floor pan to the prop, connections to brake lamp
switch and clutch switch (not in your case) then a vacuum unit linked to the throttle plus the usual live and earths.
Fairly easy and worked well from memory though i can't remember whos kit it was
mr henderson
| posted on 18/12/08 at 04:04 PM |
That's why I said "Change throttle opening"
tomgregory2000
| posted on 18/12/08 at 05:01 PM |
could you not just use the position of the seat to adjust throttle  would make intersting driving
| posted on 18/12/08 at 06:44 PM |
I think you will find a hand throttle that doesn't have to be held by hand (fixed) is no longer legal. Unipart did a universal cruise control
kit at one stage that you had to get the correct fitting kit for your car. I managed to fit one with a Metro fitting kit to a cavalier once . Easy to
fit and adjust .
