blakep82
posted on 24/12/08 at 02:19 AM |
straight type 9 gear lever
i don't like the bend its got in it
anyone know a decent locost way of making a short straight one?
________________________
gavin174
| posted on 24/12/08 at 08:03 AM |
what bend?
the type nine stick is straight...
if you hit it hard enough where the bulge is it comes apart..
may find this too short but you can weld to it to make it longer..
a link to making a quick shift.. i made a spacer out of perspex rather than araldite..
http://www.joeybrown.co.uk/quickshift/quick.html
stevec
| posted on 24/12/08 at 09:26 AM |
I took mine appart at the rubber joint and put a thread on bit that was left.
It is just the right length for me.
Link to picture
Steve.
[Edited on 24/12/08 by stevec]
omega0684
| posted on 24/12/08 at 11:07 AM |
You could buy a Quaife Short shift type 9 lever, it will need cutting down as its about half inch thick and 9" in length but there is no bend in
it!
blakep82
| posted on 24/12/08 at 12:15 PM |
Just to clarify, its this bend here i want rid of
my gear lever has already been cut down by the last owner. i quite like the length of it, and i want to try it in the car first before i try and
shorten the throw of it.
austin man
| posted on 24/12/08 at 04:44 PM |
cut across the angle and spin through 180 reweld or clamp it in the vice and exert huge amounts of pressure
