madteg
posted on 3/1/09 at 08:13 PM |
blacktop alternator bracket
Does anybody know the spacings of the holes on the block so i can make one without removing it, thanks Kev.
jacko
| posted on 3/1/09 at 08:29 PM |
Which side of the engine?
look in dunk3 photos its for n/s of the engine
madteg
| posted on 3/1/09 at 08:38 PM |
At the moment its on o/s under inlet manifold but it might be better on n/s.
jacko
| posted on 3/1/09 at 08:45 PM |
I am just trying to make one at the moment for the n/s but it is very tight
i am trying to make it for dunk3 that's why i said look in his photos
Jacko
madteg
| posted on 3/1/09 at 08:53 PM |
Thanks for the info, i will stick to the o/s as i have a large lucas one at the moment and i am fitting a nippon denso small one.
dunk3
| posted on 3/1/09 at 09:39 PM |
alternator mounts
Hi madteg i have just took these measurements for the off side alternator mounts, i hope this helps.
madteg
| posted on 3/1/09 at 09:56 PM |
Thanks for the reply but are all measurements from top line as cant make tail of the 50mm and the 45mm as they look on the same line, Thanks again.
dunk3
| posted on 3/1/09 at 10:05 PM |
Yes from top line, its 50mm on the left because the bottom hole is offset. sorry about crap drawing.
[Edited on 3/1/09 by dunk3]
