Matysiak
| posted on 5/1/09 at 08:57 AM |
Xflow breather
I have a freshly rebuilt 1660 x flow that is let it's guts out every time i rev it, either though the dipstick or my breather bottle.
I have a breather catch tank connected to the standard tin box with the PCV valve (Centre removed) feeding it. The other pipe on the breather tank
vents to the atmosphere. However, it fills the pint breather tank in a few minutes.
The oil level appears fine, although it is a customer made baffled/winged sump.
Is my set up wrong?
Mr Whippy
| posted on 5/1/09 at 09:14 AM |
I would be tempted to vent the rocker cover instead and block the old vent pipe connection. Does it stop if you remove the oil filler cap? It might be
the new sump which could be not draining past the baffle quick enough and over filling (flooding) the back of the sump around the area which the PCV
valve vent is located thus the oils being blown out. If so a few holes in the baffle may also cure this as shown in my rubbish picture
r1_pete
| posted on 5/1/09 at 09:30 AM |
The pcv valve relies on inlet manifold vacuum to open it at higher revs and vent the crankcase. With your catch tank arrangement there is no vacuum to
open the valve, hence the crankcase pressurises.
edit better ignore that you've bypassed the valve...
[Edited on 5/1/09 by r1_pete]
procomp
| posted on 5/1/09 at 09:32 AM |
Hi ^^^ eh block the block breather off and breath through the rocker only are you mad.
The regular way of a breather setup on the cross-flows is to take the breather from the block into the rocker cover and breathe the rocker cover into
the catch tank using a 1" dia hose. Although it needs to be done with a bit of baffling so the rockers are not just pumping it out of the
breather.
However if you are breathing that much oil out through the breather i would suggest getting a compression test done. I would suspect you are lacking
a great deal of compression and blowing it past the rings and pressuring the sump hence the heavy breathing. Or seriously over filled the sump. Dose
the sump that has been modded have a larger capacity of oil. Either way make sure you are not over filling on the dipstick. Is it throwing the oil out
whilst stationary with revs or only when actualy driving.
Cheers Matt
Matysiak
I removed the centre on the valve, it doesn't restrict anymore.
Matysiak
| posted on 5/1/09 at 09:38 AM |
It throws more oil out while driving, but if you rev while still a little comes out.
The sumps holds a lot more oil, but i an not sure how full it should be. Based on the dipstick i got with the engine (Before i rebuilt it) it looks
fine.
I need to check. I am assuming that the oil level must only ever be in the deepest part of the sump, never getting into the shallower section where
the rods can whip it up?
Mr Whippy
| posted on 5/1/09 at 09:52 AM |
well that's what I was saying, if the baffle doesn't let the shallow section drain then it will be thrown all over the place by the crank.
The oil pours out between the main bearings and will quickly fill a sump, even the back of it
Matysiak
| posted on 5/1/09 at 10:38 AM |
Now i understand. My sump doesn't have any baffling preventing it from flowing back into the deeper part. It just has a plate voevering the
deeper part with several holes in it.
| posted on 5/1/09 at 06:13 PM |
Lower the oil level to just above the minimum mark. My old engine used to leave a smoke screen behind if I booted it with the oil at max.
