Chris Leonard
| posted on 31/1/04 at 01:54 PM |
its still knocking
Well I renewed the big ends in my crossflow and its still knocking
Still coming from the back: oil pressure OK, ticks over without any knocking, blip the engine sometimes it starts making a noise, blip it again and it
shuts up.
any more suggestions
Cheers Chris
dozracing
| posted on 31/1/04 at 01:58 PM |
Small ends, mains? Piston rings?
westdown
| posted on 31/1/04 at 02:00 PM |
Hi
Have you put the thrust washers back in?
Dave
Chris Leonard
| posted on 31/1/04 at 02:45 PM |
errrrrrrrrrrrrrrrrrr
dont think I took any out!
I had better look in the manual
Mark Allanson
| posted on 31/1/04 at 03:13 PM |
If you have play in the crank (no/loose thrust washers), it will worsen, improve as you operate the clutch
Mix
| posted on 31/1/04 at 04:02 PM |
Did you check the crankshaft journals for wear / ovality??
Mick
Chris Leonard
| posted on 1/2/04 at 06:42 PM |
I've decieded to scrap the engine and go for the other one I have. It has a single score down one barrel, but its not too deep so hopefully
it'll be OK
