GO
posted on 1/2/04 at 08:06 PM |
Twin engined
What are the options for linking two engines together. Or do you not actually need to link them?
I'm specifically thinking bike engines.
Anyone know how tiger did it on their beast? Is the tiger 4wd?
david walker
posted on 1/2/04 at 09:27 PM |
The twin engined Tigers were built by a pal of mine - Chris Allanson from Hornsea.
His first two cars were 2wd Westfields with ZX9 engines. The first of the Tigers was also 2wd. The later cars - including the one that holds the world
0-60 speed record for a roadgoing car is 4wd.
These cars are now fairly special - injected ZX12s, 4 wd, data logging, traction control, abs etc. I think he'll sell you a new one for about
£40k.
The 2 wd cars have short props linked through to a special "collector gearbox, which has one output to the rear wheels. It also incorporates
reverse. Obviusly the prop on the front engine is longer than the rear one. I know who makes them but you probably have to buy one through Chris.
There will be no change from two grand.
The 4wd car transmissions run independently both to Cossie LSDs' fore and aft. In this repect they are mechanically independent. But beware
there is a considerable amount of electronic wizardry to keep both in sync and keep it relatively safe.
By the way they will do 0 to 100 and back to 0 in 10 seconds!
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
chrisg
posted on 2/2/04 at 06:54 PM |
You know, you can call me thick(you probably have already) but how are these twin engined cars faster?
I mean if, say your bike engine turns at 14000 rpm, and you second engine turns at 14000 rpm , then 14000 rpm is whats going into the gear box, you
can't get more revolutions at the wheels, is it all in the increased torque, or have I missed something?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Carl.H
posted on 2/2/04 at 07:06 PM |
I would have thought that double the torque would help a lot + more rubber to get the extra power down (4wd).
I drink to make other people interesting.
david walker
posted on 2/2/04 at 07:35 PM |
Chris, I would have thought it was an easy one to figure - would a 14000 rpm moped engine do the business - no. Without the power (torque x revs) the
engine dies when you drop the clutch. The twins don't die, believe me!
Stu16v
posted on 2/2/04 at 08:51 PM |
Unless Stiff Needle is driving it of course....
The electronic 'wizardry' is vitally important on the 4WD cars, it's the virtual 'centre diff' if you like. Without it,
as the car accelerates hard, the front wheels go light as the weight is transfered to the rear-result, front wheels loose traction and start spinning
madly, effectively making you a passenger in a ballistic missile with no steering!
Me too, and I would imagine you are dead right there David, as a lot of work went into the design/manufacture of the box, specifically commissioned by
Chris.
Chrisg, think of two bike engines as a V8, but instead of being joined at the crank, they are joined at the propshaft, or in the case of the 4WD, the
road.....
Mark Allanson
posted on 2/2/04 at 10:49 PM |
Who!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Simon
posted on 3/2/04 at 12:33 AM |
"The twin engined Tigers were built by a pal of mine - Chris Allanson from Hornsea"
A relative?
Simon
Jon Ison
posted on 3/2/04 at 02:57 PM |
Chris of Z cars autograss fame, the home of bike engines into car transplants
stephen_gusterson
posted on 3/2/04 at 07:25 PM |
i bought one of his loaves once
atb
steve
