Northy
posted on 1/2/04 at 09:15 PM |
Senders for a VX
Its soon going to be time to buy some gauges for the car.
Does anyone know what thread size and pitch I require for water temp, oil temp and oil pressure? And do I need some sort of T piece or something to
fit oil temp and pressure?
Graham
Ben_Copeland
posted on 1/2/04 at 09:33 PM |
Depends on the gauges i guess... can you use the original senders? Water temp, oil pressure are available standard and fit straight in. Oil temp is
not standard fitment from what i remember. Most people drill and tap it into an oil way or sump. Sorry i dont know about the threads and stuff. If
you got the old senders you can use a thread gauge
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Northy
posted on 1/2/04 at 09:55 PM |
Isn't the standard oil pressure sender an On/Off type of thing, just for a warning light? I wanted a guage as well.
Graham
Ben_Copeland
posted on 2/2/04 at 08:48 PM |
AStra GTE had oil pressure gauge too... so they had the twin sender, instead of just the light
Ben
Roadster
Northy
posted on 2/2/04 at 10:04 PM |
Cheers Ben,
Do you know what the output range is for the GTE sender and if its compatable with after market gauges?
Graham
Ben_Copeland
posted on 3/2/04 at 08:14 PM |
Sorry mate, i dont. Tho i need to find out myself for a digidash i'm having made. Only problem is they aren't cheap from vauxhall.. so
pocketing one at breakers might be only choice
Ben
Roadster
