posted on 13/2/09 at 09:33 AM |
Anyone Fitted a Trick Engine to an MG B GT?
I've owned a few, but have never fiddled with the original 1.8 Twin SU engine.
Does anyone know what the point of diminishing returns are for engine-power v's chassis-capability?
Mr Whippy
posted on 13/2/09 at 09:39 AM |
do you really want to go for more than a 3.5 rover v8? cos thats quite a common engine for them
Of course all depends on how much filler is holding it together
posted on 13/2/09 at 09:43 AM |
Nooo.... I said 'trick' engine - not prehistoric asthmatic boat-anchor!
Humbug
posted on 13/2/09 at 09:47 AM |
3.5litre V8... prehistoric maybe, but not exactly boat anchor
posted on 13/2/09 at 09:48 AM |
Trick in an MGB? How about a T16 motor... been done before many time's, on here, PPC etc.
At first glance I thought the title said 'truck' engine and the Dodge Vipor immediately came into my head![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
People have fitted Zetecs and Duratecs in them I believe. The little 1.7 Puma/Sigma engine would seem like a good choice too.
Type 9 boxes are a popular conversion too to get a 5th gear.
Mr Whippy
posted on 13/2/09 at 09:56 AM |
fit anything you want then, the v8 may be prehistoric but it still puts out a heap of torque even compared to a modern engine and you only asked how
strong the chassis was
Truth is it’s the limits of the brakes and suspension that will let you down first
I'm sure the v8 version is a right handful anyway, sure you want even more power in such a small car or are you like that guy who fitted a jag
v12?
If you really want a proper handling one, why not build a spaceframe irs chassis similar to a 7 and drop the MG shell over it? that would be a
laugh.
[Edited on 13/2/09 by Mr Whippy]
posted on 13/2/09 at 10:12 AM |
quote: Originally posted by Mr Whippy
Fit anything you want then...
Ooooh... get you!
laugh.
Now there's a thought! Do you know of any reference for such a project, or is it a 'make it up as I go along' jobbie?
Mr Whippy
posted on 13/2/09 at 10:31 AM |
there a few on here building spaceframed classics
wheelbase and running gear layout look close to a 7, don't see why you couldn't go that route and then weld a floorless shell to the new
chassis. Only bit to 'make up' is the sheeting between the two. Certainly save a fortune buying upgraded MG bits to try and bring a
60's car up to date
r1_pete
posted on 13/2/09 at 10:34 AM |
Take a look in my archive, I've put a zetec in mine.
Brakes and suspension can all be successfully upgraded, MGRV8 front is the ultimate, many coil over aftermarkets too. Vented drilled etc discs readily
available as are multi pot calipers - Austin princess used to be the locost way but not any more, SD1 4 pots fit in steel wheels but not wires. You
can get 4 link setups fro the rear etc. etc.
The chassis is imensely strong, and every component is available so no reason to have a patched up rust bucket.
posted on 13/2/09 at 10:45 AM |
don't see why you couldn't go that route and then weld a floorless shell to the new chassis. Only bit to 'make up' is the
sheeting between the two. Certainly save a fortune buying upgraded MG bits to try and bring a 60's car up to date
why use the shell?
space fram then clad with GRP bits; pretty sure front and rear wings and bonnet are avaialable, just need to make bootlid and doors.
Hammerhead
posted on 13/2/09 at 11:22 AM |
there is a good blog of a guy putting a rover k-series vvc engine in one. Think the site is called mg spigot or something. Google will help you.
bitsilly
posted on 13/2/09 at 11:31 AM |
There is loads of info on K series into midgets so that would seem a good choice. My friend has one and there is a lot of parts/advice/solutions etc
which would transfer well to the b.
Also there are established experts in MG to k series. A big place in Bath which I can find out about from said mate if you like. May be worth a
call.
At track days with that midget there is so much power that half shafts have gone, diffs exploded and brake in urgent need of upgrading!
For the B at least you can get up-rated V8 bushes and components, in fact uprated almost everything through the club including light weight panels.
uklee70
posted on 13/2/09 at 11:38 AM |
I Have been thinking of this for a while
I would love a modern engine in a MGBGT as everyday transport
My idea was BMW engine and sebring arches
It would be good to go for BMW running gear
I would be really interested if there were some webs to read
Lee
speedyxjs
posted on 13/2/09 at 11:40 AM |
How about this?
posted on 13/2/09 at 11:53 AM |
me too but thniking of space framing a frogeye sprite - I believe banham do the body parts.
NB a roadster is better mind.
posted on 13/2/09 at 12:34 PM |
Rover T16 or M16 is the best bet very smooth engine -- as much low down torque as the 18 B series but once past 3500 revs it really comes on song.
Non-turbo produces 140 bhp in mpi form
Turbo version output depends what version you find. as the pistons on the 172bhp non- Sport variant don't like much more boost than standard.
but 220 bhp is available with a simple mod if you find a Sport spec 192 bhp engine
[Edited on 13/2/09 by britishtrident]
bikenuts
posted on 13/2/09 at 12:44 PM |
Have a pep at this;
http://forums.nicoclub.com/zerothread/380424-1977-mgb-roadster-with-ca18det
or this;
http://www.britishv8.org/MG/ToddBudde.htm
or this;
http://www.britishv8.org/MG/KyleBingham.htm
or these;
http://www.fastcarsinc.com/mgbv8.htm
hicost blade
posted on 13/2/09 at 01:13 PM |
http://www.mgcars.org.uk/frontline/index.htm
Met these guys the other day. Up to 350bhp from their K series conversions on Spidgets and B's.
iank
posted on 13/2/09 at 01:21 PM |
Banham did one (based on a mini floor ) but have been bankrupt for years, did you mean Tifosi?
http://www.freewebs.com/tifosirana/tifosirana.htm
For the MGB, what about a Nissan turbo?
http://www.youtube.com/watch?v=lZOACgLWRy8
Anonymous
bitsilly
posted on 13/2/09 at 05:35 PM |
Frontline were the people in Bath I was takling about.
They are superb and well worth a visit on the midget/sprite front.
They can even build a lightweight spaceframe sprite with their own suspension and drivetrain and lightweight panels.
