Mr Whippy
| posted on 23/2/09 at 08:19 AM |
That’s torn it :o(
Oops due to a stupid design flaw it that the only way to release this engine bush causes the bush to be destroyed! I have a torn one now what’s
worse is its about as easy to get as a dodo egg due to it being off the Bluebirds rear engine mount. So what now, don’t know tbh though the Nissan
micra might have a bush the same but not sure.
Anyone able to help here or suggest a solution, might actually come to me having to modify this mounting or make another but in the interests of
originality I’d rather no tbh
thanks
r1_pete
| posted on 23/2/09 at 08:39 AM |
Have a look on the polly bush and superflex sites, there may be some universal suspension bush you can modify.
Mr Whippy
| posted on 23/2/09 at 08:49 AM |
cheers but my only concern with replacing it with a harder bush is tonnes of engine noise being transmitted. I can defect the bush with one finger and
the cars meant to be very quiet.
minitici
| posted on 23/2/09 at 08:51 AM |
How about moulding a new one using something like this?
Frost Rubber Moulding Kit
| posted on 23/2/09 at 09:05 AM |
If the 'design flaw' is that the bush is pressed in, then most cars have this fault!
I'm in a simmilar situation, the engine mounts on my Fiat Coupe are getting pretty tired, but there is no way I am paying the prices that Fiat
are asking for new ones (something like £190, £150, £120 and £90 depending on which of the four mounts you want). That's IF you can get them,
they put them on back order until they have sufficient orders to make a batch
My plan is to simply look around for something similar of a more mainstream car and adapt it to fit.
r1_pete
| posted on 23/2/09 at 09:10 AM |
Might be worth kicking a search off Here
| posted on 23/2/09 at 09:12 AM |
volvo 850 engine has one like that, I could measure it but not till I get home.
yours may be soft due to age?
Mr Whippy
| posted on 23/2/09 at 09:27 AM |
well the reason it sheared was me trying to remove the arm! there's no way to prevent the center turning due to there being a captive bolt going
though it thus it just ripped...
minitici, that rubber molding kit might work though, I'll have a shifty
cheers guys for all the help
[Edited on 23/2/09 by Mr Whippy]
Mr Whippy
| posted on 23/2/09 at 10:24 AM |
SORTED!
superb the parts gateway sites got a replacement arm that's being delivered tomorrow cheers R1_pete for the link
r1_pete
| posted on 23/2/09 at 10:59 AM |
Brilliant... HTH.
Canada EH!
| posted on 23/2/09 at 02:52 PM |
Had something like that on my Datsun 1200 race car, replaced it with Volvo 122 bushing, using same on the Locost.
