posted on 10/2/04 at 08:50 PM |
Weber DGV
I have a Weber DGV ("manual-choke" version of DGAV) from a Sierra, re-jetted for the x-flow. This works just fine, but I have a problem
with the fuel pipe.
As you can see, the inlet is on the engine side, so every time that I want to take off the rocker cover I have to undo all the fuel pipework.
Is it possible to drill the inlet on the other side of the "Y" shaped bit (where the inlet fuel filter is), or can I get one off another
DGV carb from another model? It will make the whole thing a lot easier if I can get the inlet coming in from the left, as you look at the picture,
rather than the right.
All advice gratefully accepted, etc.
cheers,
Carl.H
posted on 10/2/04 at 09:34 PM |
Is there a little metal bung in the other half of the Y peace, if so I would have thought you could knock or drill this out, and machine a brass pipe
up to tightly fit in the hole.
Or couldn’t you just attach an elbow to existing inlet, see very crude pic
Elbow
hope this helps
I drink to make other people interesting.
Stu16v
posted on 10/2/04 at 10:55 PM |
[pedant]
How often do you expect to take the rocker cover off?
[/pedant].
Just being realistic mate...
Surrey Dave
posted on 10/2/04 at 11:13 PM |
I have this carb on my car and , I have the screw in pipe fitting like yours one side and a screw in brass blanking bung the other so i just swap the
pipe for the bung, so you can either drill/tap yours or find another carb and nick the top off it.
If you end up with spares I could do with the manual choke parts for mine , they've been removed.
posted on 11/2/04 at 08:49 AM |
quote: Originally posted by Stu16v
[pedant]
[/pedant].
I've already had to take it off twice...
I have a hidden agenda - I want to replace the existing very scruffy cover with a nice shiny aluminium one, but they're bigger and squarer, so
the pipe's got to move.
Does the inlet pipe just unscrew? I haven't had the courage to try it! The other side looks like it's never been drilled (or it's a
glued-in bung). If it's a standard metric thread then I can easily drill & tap the hole.
As for the manual choke - I bought a conversion kit from my local motor factors for around £15, 'cos the auto choke mechanism was screwed.
cheers,
Stu16v
posted on 11/2/04 at 06:56 PM |
Ahh....
Fair comment. I just assumed you were creating a lot of work, just to save ten minutes extra work every ten thousand miles.....
Cheers, Stu.
