Author: Subject: Air filters
Simon
posted on 11/2/04 at 12:11 PM Reply With Quote
Air filters
Chaps,
If I use the original Rover filter tube and connecting pipework, my engine is quite wide - resulting in a huge bonnet bulge/scoop - not what I want!.
I'm thinking that I should get some "half-cylinder" type filters, and bolt them directly to the carbs - then they can stick through the bonnet.
Trouble is, is the price. £45 + each seems a bit steep.
Has anyone got any other suggestions or where to get them for about £20 each - I can cope with that!
Please don't suggest Weber or Holley, as that really would be stretching the budget.
Thanks and ATB
Simon
mackie
posted on 11/2/04 at 01:26 PM Reply With Quote
What does the SVA manual say about bonnet protrusions?
I think we are going to have a bump/scoop over our plenum and hopefully the airflow meter and filter will tuck away down the side nicely.
posted on 11/2/04 at 01:35 PM Reply With Quote
They come under the headings of "mustn't have sharp bits" and "mustn't obstruct the view". Otherwise, you can do what you want!
DJ
Donners90
posted on 11/2/04 at 02:49 PM Reply With Quote
Hows about something like this??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2459253699&category=38786
Even if you don't win (or even bit) it may give you some ideas. If you got it you could sell your old manifold and fit this one???
D90
No connection!
[Edited on 11-2-2004 by Donners90]
timf
posted on 11/2/04 at 03:06 PM Reply With Quote
why not adapt a set of mini k&n`s to suit
Simon
posted on 11/2/04 at 03:23 PM Reply With Quote
Donners,
Yeah - seen that - MGB V8 manifold, apparently they don't breathe very well.
But, as I have a spare manifold or two lying around, I may think about making something like it.
Tim,
Are they the small (5"? dia) pancake filters), yep thought about that too, though may finally end up with a combo of
the MGB V8 manifold and small pancakes.
Cheers for suggestions anyway chaps, I think I still have a couple of days to think about it!!
Simon
timf
posted on 11/2/04 at 05:21 PM Reply With Quote
could always go for the modify sd1 to take webber 38 dgas carb ie machine of the inverted V on the manifold and make a flange for the carb to sit on.
also some of the mini k&n`s are conical
[Edited on 11/2/04 by timf]
timf
posted on 17/2/04 at 09:12 AM Reply With Quote
simon one for you on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2460243144&category=36680
Spyderman
posted on 17/2/04 at 01:53 PM Reply With Quote
I wouldn't bother with pancake filters if at all possible. They are too restrictive!
If necessary use some flexible hose and fit a remote filter in the nose.
At a push you could use household ducting. The sort you fit to the cooker and bathroom extractors.
Anything has to be better than pancake filters!
Spyderman
