AdrianH
posted on 28/2/09 at 09:42 PM |
Question on rocker covers CVH engines?
I am thinking that someone on here would have changed heads at some time from a 1.8 to a 1.6 CVH head, or knows more then me on this.
Trying to find out if the 1.6 rocker cover will fit on a 1.8 head, trying to move the filler lump from front of engine to back, need to know if holes
line up etc.
Adrian
Why do I have to make the tools to finish the job? More time then money.
ss1turbo
posted on 28/2/09 at 09:54 PM |
I've got 1.8 rocker covers on 2 of my 1.6 CVH's as the oil filler saves me lubricating the dizzy every time...does that answer the
question?
1.8 gasket is much better as well...
Long live RWD...
ss1turbo
posted on 28/2/09 at 09:55 PM |
Oops...just re-read it..
1.8 head has the 'stat housing in the inlet manifold, 1.6 has it next to the dizzy, so rather different.
Long live RWD...
whitestu
posted on 28/2/09 at 10:01 PM |
1.6 heads fit 1.8, but without changing pistons will give a low CR. Fine if you want to turbo charge, but not good for NA engines.
Stu
AdrianH
posted on 28/2/09 at 10:08 PM |
I think my question may be misleading, so trying to explain a bit more.
I am sticking with a 1.8 head on a 1.8 CVH so not swapping them over.
But I want to remove the oil filler from the front end of the engine to the flywheel end of the engine. Reason is the filler cap is in the way of the
bonnet when in 1.8 position, but should be out of line at flywheel end.
The 1.6 and 1.8 both seem to have the oil breather pipes in same place but found nothing saying if the gaskets are the same and if both have adequate
clearance.
So would like to fit 1.6 rocker cover on 1.8 engine.
Adrian
ss1turbo
posted on 28/2/09 at 10:17 PM |
Adrian
Yes is the simple answer as i've done it the other way round.
Long live RWD...
jacko
posted on 28/2/09 at 10:20 PM |
Think this is your answer
AdrianH
Excellent, will scan the bay for 1.6 rockers close to me.
Adrian
wrigglypig
posted on 28/2/09 at 10:31 PM |
I am building the roadster as well and have the 1.8cvh I have just had my rocker cover powder coated, does this mean its wasted?? as it will foul the
bonett?? Bugger! or can the engine position be slightly adjusted?? I hav nt got the book to hand, but is there, or does anyone have a maximum
measurement that the top of the engine can protrude above the top rails?? without fouling fabbys bonnett
[Edited on 28/2/09 by wrigglypig]
AdrianH
posted on 28/2/09 at 11:11 PM |
Hello again.
Now not sure about Triton bonnet as he is doing a
new one with the bulge. I have the Triton scuttle in place and did a dry fit of the nose cone tonight and could not rest a straight edge from the lip
of one to the lip of the other over the top of the oil filler cap, hence why I posted the question.
I am drilling to fit rivnuts tomorrow morning and will fix the nose in place properly.
I am going for an aluminium bonnet at present as I will have to stick a hole there for the carb inlet.
This is with the inch off the sump and the modified sump one inch below the chassis.
Adrian
wrigglypig
posted on 28/2/09 at 11:52 PM |
Cheers Adrian, I dont have to worry about the carb as I have the bike carbs fitted
Surrey Dave
posted on 1/3/09 at 11:50 AM |
Like This ?
Cut it off welded it on the back , and covered the front with low flat plate.
![](/galpreviews/a897508-Carbs On Car 2 sml.jpg) ![Rescued attachment Carbs On Car 2 sml.jpg](/gallery/a897508-Carbs On Car 2 sml.jpg) Rescued attachment Carbs On Car 2 sml.jpg
AdrianH
posted on 1/3/09 at 01:31 PM |
That shows there are no height issues under the cover.
That is one possibility.
Adrian
