Author: Subject: Dim Question- How Tight Cam Belt?
edspurrier
posted on 3/3/09 at 07:47 PM Reply With Quote
Just a thought while looking at other things, but my cam belt seems fairly slack to me - quite alot of laxity in it. The tensioner was fitted aboiut 480 miles ago with new belt and there's a telltale paint mark which show it hasn;t moved, but is there a way to see how tight it should be?
thanks
ps Zetec 2 lite silvertop
[Edited on 3/3/09 by edspurrier]
flak monkey
posted on 3/3/09 at 07:50 PM Reply With Quote
About 90 deg twist on the longest run is a good guide.
Sera
http://www.motosera.com
posted on 3/3/09 at 07:55 PM Reply With Quote
Some of the early silvertop Zetecs did not have a tensioner spring but should have been modified by now with a new spring and locating bolt . Did you fit one? Easy to adjust tension but I would recheck timing just in case, Make sure you turn the engine over a few times and recheck.
Daddylonglegs
posted on 3/3/09 at 08:17 PM Reply With Quote
90 deg check works in 99% of cases.
I'd definitely go with testing a few turns by hand before you start it to check the timing is OK.
I had a Laguna that the timing belt went slack on and it managed to jump a couple of teeth. Short story is it cost about £1000 to put right, and that was doing it myself
JB
Paul TigerB6
posted on 3/3/09 at 08:21 PM Reply With Quote
As above, the original belt was fitted in the factory and tensioned by machine without the need for a spring to be fitted as per the book of lies (by some Haynes Manual bloke). Cambelt kits generally come with a spring to connect to the adjuster pulley and post to screw into the engine to hook it around which then tensions the pulley correctly.
Did you fit this NEW spring or reset it to the original factory mark?
edspurrier
posted on 3/3/09 at 08:23 PM Reply With Quote
Engine was rebuilt for me so I didn't fit it. Came with a new cambelt tensioner kit though.
whitestu
posted on 3/3/09 at 08:48 PM Reply With Quote
On my blacktop the tension isn't fixed, but is controlled by the spring in the tensioner. It easily moves if given a bit of a push.
stu
mediabloke
posted on 3/3/09 at 11:51 PM Reply With Quote
The Vx small blocks have markers and a flag on the tensioner for "new" and "used" belts. It doesn't half give you some confidence when you're tensioning up after rebuild.
Do others around the same age (Zetecs / Duratecs / 4AGE) have the same?
Otherwise, the 90 deg test also works with my Ecotec.
Francis.
bimbleuk
posted on 4/3/09 at 09:22 AM Reply With Quote
On the 20V 4AGE there are two types one is the more common pulley tensioned by a spring. The later type has a damped spring in a metal body. I had the later type which can wear and loose tension which happened to and the engine lost a lot of power but luckily was a "safe " design and didn't bend anything. The 90 deg check is a quick check but sometimes the belt runs are too short to be accurate.
Best gadget I saw recently was an electronic belt tension gauge. You just held the sensor near the belt and gave it a flick to get a reading, brilliant!
