speedyxjs
| posted on 4/3/09 at 08:38 PM |
High pressure pump and filter
Can you use one in a carb setup? I have a standard pump and filter for a FI engine, can i use these on carbs or do i need to buy low pressure ones?
jacko
| posted on 4/3/09 at 08:40 PM |
Low the old Jags used twin SU pumps
speedyxjs
| posted on 4/3/09 at 08:46 PM |
The pump i have is off an x300 (94 - 97)
Antnicuk
you will blow the carb apart with an FI Pump. Facet do some low pressure high flow ones or get one from a car that the carbs came from if applicable.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
mark chandler
| posted on 4/3/09 at 09:02 PM |
You can use an EFI pump but will need to supply a fuel return and add a restrictor in this, the fuel pipe then becomes a low pressure fuel rail.
Better to get a facet pump though, have a look at non efi rangerovers pumps on ebay.
One of these
chaps will
do.
Regards Mark
[Edited on 4/3/09 by mark chandler]
| posted on 4/3/09 at 10:20 PM |
Why would you want to do that? You'ld risk knackered the carbs.
EFi pumps are usually worth more 2nd hand than carbed pumps. Flog it on Ebay and buy yourself a cheap low pressure pump!!!
mark chandler
| posted on 4/3/09 at 11:04 PM |
I think the price is swinging, the pump I have indicated above is for 2 x 1.5" SU carbs, the jag items are 2" SU carbs but this was a
percieved upgrade by some on v8 rovers at some distant point in the past.
Its an unbranded facet type pump so 1/2 the price, will tick away until up to pressure.
| posted on 5/3/09 at 08:23 AM |
no, the higher pressure (circa 30 psi) is gonna play havoc with your floats resulting in overfuelling, fuel spilling out hte overflow and possible
damagage.
carbs run at 3 to 4 psi max.
twin low pressure would be thge way to go if you are worried about flow.
take a look at FSE - teh ysell the facet solid state - in 3 flavours (increas in flow).
I have the middle one on a 3.5 l V8 with twin 1 3/4 inch SUs and have not had any fuelling issues (well, not unitl the filter got blocked but that is
not the pumps fault, well not directly).
| posted on 5/3/09 at 08:31 AM |
60's and 70's Jags used two big SU electric pumps one for each tank BUT only one worked at a time -- a changeover switch on the dash
controlled which tank & pump was in use.
The EFI pump won't work however you can pick up Rover SD1 carb model external electric pumps off Ebay cheap.
speedyxjs
| posted on 5/3/09 at 09:02 AM |
Thanks guys. The old pump can go on ebay when i get round to it. Will the filter be ok or is that designed for higher pressure flow?
| posted on 5/3/09 at 10:32 AM |
It'll handle it BUT HP filters tend to be a lot bigger and heavier than the cheap plastic LP filters. It's a small consideration. But
fundamentally you won't have a problem running a HP filter in place of a LP filter.....
