Author: Subject: Engine mount failure...fixed
flak monkey
posted on 7/3/09 at 11:41 AM Reply With Quote
Oops, maybe the pinto has a bit more power these days!
Broken the offside engine mount, not failed at the weld, but about 1" down from the block. Its the mount which has all the tensile force on...
Another job for this afternoon! Was hoping to go out for a blat seeings a sits so nice outside too!
I'll post a piccie or 2 later...
[Edited on 13/3/09 by flak monkey]
Sera
http://www.motosera.com
Ben_Copeland
posted on 7/3/09 at 12:57 PM Reply With Quote
Whoops.... who'd a thought it
Must be your driving
Ben
Locost Map on Google Maps
Enter Your Details Here
TGR-ECOSSE
posted on 7/3/09 at 01:36 PM Reply With Quote
We had an engine mount failure in the stock car and discovered it was caused by a fault in the clutch and accelerator pedals. With the engine running if you pressed the accelerator pedal to the floor and let the clutch off the floor at the same time it broke the engine mounts Hope this helps
Ronnie
flak monkey
posted on 7/3/09 at 02:57 PM Reply With Quote
Ronnie
So thats what I have been doing wrong!
Was quite suprised that it failed. It was a piece of 25x25x1.6mm box. Think I'll make the new one from 14swg!
Sera
Chippy
posted on 7/3/09 at 03:11 PM Reply With Quote
I used 10g on mine, maybe overkill, but it has the weight of a V6 hanging on it, :-) and it ain't broke , (yet)!!! Cheers Ray
clairetoo
posted on 7/3/09 at 04:06 PM Reply With Quote
Mine are 1 5/8 seamless (left overs from making my roll bar braces) - maybe overkill , but they aint broke yet
Its cuz I is blond , innit
Claire xx
Will weld for food......
flak monkey
posted on 7/3/09 at 04:21 PM Reply With Quote
I'll see what I can get hold of to make a new pair...
Sera
pocket rocket
posted on 7/3/09 at 06:20 PM Reply With Quote
dam, i can't believe the metal has let go before the rubber part of the mount
Dam...iv consused my ability with my intentions!
gazza285
posted on 7/3/09 at 11:06 PM Reply With Quote
That's quite a weedy engine mount, not surprised it broke, 10gauge or 3mm would be better suited. Made mine out of 50 x 25 x 3 box section.
mr henderson
posted on 8/3/09 at 08:48 AM Reply With Quote
I usually think in terms of 3mm for engine mounts. I've got a big sheet of it, and cut pieces off and weld them together as required.
Another approach would be to use the 1.6, if convenient, and strengthen it with extra plates
John
Benzine
posted on 9/3/09 at 09:37 PM Reply With Quote
That's how I made mine, very strong indeed.
flak monkey
posted on 9/3/09 at 09:43 PM Reply With Quote
Made a new one tonight from 3mm wall 30mm tube. Looks a darn sight more substantial... Just need to weld it up now and make one for the other side too!
Sera
flak monkey
posted on 13/3/09 at 05:23 PM Reply With Quote
Problem solved hopefully! Two new mounts now fitted, so back on the road again...if my welds hold up!
Sera
pocket rocket
posted on 13/3/09 at 06:13 PM Reply With Quote
nice welding dude
flak monkey
posted on 13/3/09 at 06:23 PM Reply With Quote
Originally posted by pocket rocket
nice welding dude
Cheers, its a long time since I tackled MIG welding!
Sera
pocket rocket
posted on 14/3/09 at 02:04 PM Reply With Quote
did you use gas or gasless flux cored wire?
flak monkey
posted on 14/3/09 at 02:39 PM Reply With Quote
Thats standard mig welding with gas.
Sera
NS Dev
posted on 15/3/09 at 02:00 PM Reply With Quote
at a guess, using CO2, hence the spatter (mine is the same, I use it too) get a can or two of anti-spatter spray, makes things much easier! (only a quid a can)
On the original mount, it was the weld that started the failure by the way, it cracked from the heat affected zone, pretty normal!
