paul the 6th
| posted on 7/3/09 at 03:38 PM |
Bike carb mounting angle - is it critcal on car engines?
In the quest to find some carbs to suit my 1.8 cvh, a friend mentioned about the mounting angle of the carbs. In their original orientation mounted to
a gsxr750 engine, the carbs would be slightly angled pointing down towards inlets, but I was just going to keep it simple & mount the square on
& flat with the inlets.
Is this likely to cause any issues at all? Thanks in advance
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
| posted on 7/3/09 at 03:42 PM |
My CBR600FX carbs were almost vertical on the bike - now they're about 30 degrees above horizontal.
Doesn't seem to bother them...
stevec
| posted on 7/3/09 at 04:01 PM |
I think its the float bowls that need to be at the correct angle or this may affect the fuelling.
If they are injection it probably dosn't matter
[Edited on 7/3/09 by stevec]
RichardK
| posted on 7/3/09 at 04:04 PM |
I got my float bowls horizontal but in reality doesn't seem to bother them, after all bikes don'y run out of puff when they're on
the back wheel
R
Gallery updated 11/01/2011
jacko
| posted on 7/3/09 at 04:31 PM |
  carbs on manifold
This is how mine are it pip under the carbs is vertical
skibum
| posted on 7/3/09 at 05:22 PM |
Ruuning Zx9 carbs and the float bowls are horizontal no probs so far
Matt
whitestu
| posted on 7/3/09 at 05:33 PM |
My ZX6R carbs are mounted straight onto the head and work perfectly.
stu
