Author: Subject: another engine mount questions
posted on 11/3/09 at 11:48 AM Reply With Quote
2 questions.
1. what is going rate for mk2 escort engine mounts, like these
2. secondly, as I would be using those ^^^, what would be a good design of engine mount to allow vertical adjustment as well as fore/aft?
my idea is shown below.
I would use shims made from steel plate, or maybe aluminium, to raise the mount.
And use slots in the mount and a moveable plate to allow for adjustment in other dimensions. This will bolt on.
Good or can you think of a better/simpler/cheaper way? (I am not sure how well I be able to measure the actual engine position hence allowing for adjustment). Rescued attachment mounts.JPG
posted on 11/3/09 at 11:52 AM Reply With Quote
hmmm, I see burton power do the mount without the rubber but with slot; and rubber bobbin so there is some adjustabillity designed in.
Mr Whippy
posted on 11/3/09 at 12:10 PM Reply With Quote
I'd use shims as the slots in the Burton power ones do are there to allow for different thicknesses of rubber mount and not the height of the engine. You could make the shims out of hard wood tbh as the loading over such a large area is very low.
dhutch
posted on 11/3/09 at 12:34 PM Reply With Quote
Originally posted by 02GF74
While we're on the topic, what mounts do people use, manufacture/stiffness/etc.
- Mine look very much like the one above but are begining to fail.
Daniel
Mr Whippy
posted on 11/3/09 at 01:11 PM Reply With Quote
I used transit diesel ones in the Falcon as they are slightly larger but much softer than those for the petrol engines. I wanted the car to be smooth for long journeys and you can't feel any vibration when the engines running
Canada EH!
posted on 11/3/09 at 02:54 PM Reply With Quote
Those mounts look like Volvo 122, which is what I used on my Toyota 4 AGE locost, I also used them on a Datsun 1200 race car many years ago after the Datsun mounts kept delaminating, no more problems.
posted on 11/3/09 at 06:39 PM Reply With Quote
The slots are not for adjustments, it's so you can drop the engine into the mountings as it would be otherwise impossible!
Mark Allanson
posted on 11/3/09 at 09:19 PM Reply With Quote
Landrover mounts?
dhutch
posted on 12/3/09 at 12:11 AM Reply With Quote
Also note the mounts are angled.
- The point of intersection should cross around the point you wish the engine to rotate. Usually somewhere around the center of gravity and the line of the crankshaft/gearbox outdrive.
I will look at the volvo or landrover mounts.
Daniel
posted on 12/3/09 at 08:58 AM Reply With Quote
.... too late, I've ordered a set of the first one I shown.
