Author: Subject: 8mm microbore copper pipe
blakep82
posted on 16/3/09 at 11:42 PM Reply With Quote
i think i remmeber reading on here its ok for fuel lines? just want to check before i spend money on something else which isn't right
on compression fittings for heating, you et the olive, can you get these for microbore pipe too? is that the best way to get a good seal? i haven't got any flaring tools, and propbably won't have any need to, so looking for alternative ways.
i've got 8mm rubber pipe already, so will this be ok to slip over the copper pipe and the olive?
________________________
Simon
posted on 16/3/09 at 11:46 PM Reply With Quote
It's what I've done (but with 10mm pipe). Tested it on Sunday and no leaks.
If you do it and your car burns, I'll deny all knowledge of it
Simon
omega0684
do you have enough rubber fuel pipe already, just use that, i run steal braided rubber fuel lines all the way from tank to fuel rail and back again.
Chippy
posted on 16/3/09 at 11:47 PM Reply With Quote
Hi, yes the 8mm copper pipe is fine for use as a fuel line, I have it on mine, as do several hundred others, Just a point that may be of interest, solder on some olives at the ends, makes a nice petrol tight fit, once you have jubilee'd the rubber pipe to it. Cheers Ray
posted on 16/3/09 at 11:51 PM Reply With Quote
I found that domestic central heating pipe has a very thin wall - it kinks quite easily, and you can bend it when you push on some rubber tube (I did, anyway).
I'm seriously thinking of replacing mine with 8mm Kunifer pipe at some time in the future. Alternatively, I might just put some steel conduit up the tunnel and push some flexible tube through it.
blakep82
posted on 16/3/09 at 11:52 PM Reply With Quote
ah, yes, i bought 5m ( i think) thinking this would be plenty to run from the fuel tank to the carbs, ti was something silly like £5.50 a metre or something and yes i found it cheaper elsewhere later... but when running cables, 6m didn't go as far as expected... thought i'd be better running some copper, which works out a lot cheaper, just down the tunnel, and using the rubber pipe everywhere else
thinking about it, i only need a few metres if anyone has some to spare? say 4m to allow for mistakes?
it was just something i was thinking about, but david makes a good piont. it would be quite thin wall. i'll try running the pipe i've got down there, if i need it longer i guess i can joing extra bits on with hose joiners.
[Edited on 16/3/09 by blakep82]
MikeR
posted on 17/3/09 at 12:05 AM Reply With Quote
I've posted this many times......
Firstly i'll 95% likely to use copper pipe!
Mate used to design fuel systems for cars until he married a girl and moved.
Basically copper pipe is a no-no as the petrol reacts with the copper and something leaches out of the copper. Over time this will built up in places like on injectors. On carbs you're more likely to be ok as the tolerances are bigger. This is why production cars never use copper fuel lines.
Now the important question is how long will it take to mess up your car ? don't know. considering how many people have copper lines on their cars we're probably ok due to limited mileage.
Just wanted to make sure you make an informed decision. As I said, i'll probably use copper when i get round to making my fuel lines despite having 4 or 5 mini cooper fuel lines in my garage attic.
austin man
posted on 17/3/09 at 12:06 AM Reply With Quote
im using 10 mm from wickes no problems in 2 years, werent b&q doing a tool to put a flare onto pipe ends ???
omega0684
posted on 17/3/09 at 12:15 AM Reply With Quote
JESUS THATS EXPENSIVE! I think i only paid about £6/Metre for my braided hosing
gazza285
posted on 17/3/09 at 05:57 AM Reply With Quote
So you paid more than he did.
posted on 17/3/09 at 07:40 AM Reply With Quote
When I first heard this I did some research - there's quite a lot about it on the interwebbie...
The problem mainly happens in countries where the petrol is of poor quality and contains lots of sulphur. This reacts with the copper to form copper sulphate that can eventually block pipes and may get into the carbs/injectors. This is probably the main reason why manufacturers don't use it.
Apparently (they say) in European countries and the USA the petrol is better refined and this problem just doesn't occur.
Hopefully.
The other reason is metal fatigue - if copper pipe is allowed to vibrate it will fracture, eventually. For people like us, with our limited mileage, this is unlikely to be a problem. If you use Kunifer, then this problem goes away, near enough.
[Edited on 17/3/09 by David Jenkins]
posted on 17/3/09 at 08:05 AM Reply With Quote
The other alternative is plastic polyflex pipe which is now geting very popular with the LPG conversion industry, but it is relatively expensive.
posted on 17/3/09 at 08:12 AM Reply With Quote
One thing I have considered is to run a steel conduit or tube through the tunnel, which would make the installation and/or replacement of a flexible tube very simple. It would be quite easy to push that plastic tube through, for example.
It would also help to protect the fuel line if the propshaft let go... up to a point, anyway. It would certainly be stronger than copper or plastic, anyway!
Guinness
posted on 17/3/09 at 08:18 AM Reply With Quote
I bought a 1.5m length of 8mm aluminium pipe from B&Q. Put a slight bend in it and ran it from the diff, along the tunnel and up the sloping bit where the gearbox should be. Put a few little grooves around the ends with a file to give the rubber hose / jubilee clip something to seal against.
Rubber pipe from tank to filter to pump to inlet of pipe, then more rubber pipe from front of tunnel to carbs.
I wouldn't use rubber where it can't be regularly / easily inspected.
posted on 17/3/09 at 08:29 AM Reply With Quote
I'd be worried about using aluminium pipe - not only is it prone to work-hardening, it also age-hardens. Fine if it's in a race car that gets a good looking-over frequently, but maybe not in a road car. IMHO, of course.
As for rubber pipe - here's one I took out of my car a year or two ago (it was about 4 years old):
Guinness
posted on 17/3/09 at 08:46 AM Reply With Quote
[Heads out to garage to inspect fuel pipe]
Mike
yellow melos
posted on 17/3/09 at 11:45 AM Reply With Quote
The only time i have seen rubber pipe go like that is when somthing else has got on it ( like oil or LHM fluid )
i have had rubber fuel pipes on my car for over 6 years and it has not done that
posted on 17/3/09 at 12:04 PM Reply With Quote
That was the bit that went from the tank to the hard tubing through the tunnel - all it was exposed to was petrol on the inside, and road muck on the outside.
I think it was dodgy quality hose, which I'd bought in a local motor factors. Possibly it was old spec stuff, not proof against modern unleaded that has some nasty solvents in it such as benzine.
Dave Bailey
posted on 17/3/09 at 03:03 PM Reply With Quote
I'm using 5/16th Kunifer with double olive fittings either end. Not tested it yet but should be o.k.
flibble
posted on 17/3/09 at 03:21 PM Reply With Quote
Would stainless like THIS be better than copper, with some 8mm stainless hosetails welded to the end?
It's what I was considering for the undercar portion of my fuel lines.
Kev
posted on 17/3/09 at 05:20 PM Reply With Quote
That's what I'll probably use the next time I go into the tunnel (sounds good...).
I'm also thinking of making some brass end fittings that can be bolted to the chassis, to reduce pipe flexing.
Just a pipe dream at the moment though.
