Author: Subject: URGENT - clutch arm orientation
posted on 17/3/09 at 01:36 PM Reply With Quote
just about to mock up engine moutns so want to move gearbox as close to footwell and have enoiugh space for the cltuch arm to work.
pretty sure I know which round it goes but it seems it was fitted back to front!!
this is how I reckon it should be: Rescued attachment DSC04441.JPG
posted on 17/3/09 at 01:37 PM Reply With Quote
and another view.
the bearing is able to pivot on the tabs when this way round Rescued attachment DSC04444.JPG
Mr Whippy
posted on 17/3/09 at 01:38 PM Reply With Quote
easy way to remember is the cable goes past the engine, so as its shown in the pic is correct as the cable end sits in the channel and is pulled forward
obviously also the bearing has to push the clutch in to disengage and it can only do that by sliding forwards against the spring plate
[Edited on 17/3/09 by Mr Whippy]
posted on 17/3/09 at 01:40 PM Reply With Quote
and how it was fitted (pretty sure that is how it was but doesn;t seem right); I will need shorter cable. Rescued attachment DSC04442.JPG
Mr Whippy
posted on 17/3/09 at 01:41 PM Reply With Quote
posted on 17/3/09 at 01:44 PM Reply With Quote
and another view. bearing isn't able to pivot in this position.
this is definitely wrong as the cable nipple will not sit in recess.
the arm was loose so it may have dropped out and I fitted it back to front but I don't think so.
means the cable will be too long but that is easier to fix than getting engine mounts in wrong place. Rescued attachment DSC04446.JPG
Paul TigerB6
posted on 17/3/09 at 01:48 PM Reply With Quote
+1
Dont tell us you did that yourself!!
