posted on 18/3/09 at 08:08 PM |
Fprd 4 speed box - spigot bearing
After removing the 1300 engine, I saw lots of needle rollers inside the end of the crank
that I believe belong to the spigot bearing.
There is no mention of replacing this in the Haynes, so is this part available and how does one go about fitting it?
Hopefully it is all dandy in the new engine but would be useful to know.
flak monkey
posted on 18/3/09 at 08:11 PM |
Ford sell 'em
They arent expensive, you need to remove whats left of the old one though.
Sera
http://www.motosera.com
posted on 18/3/09 at 08:29 PM |
aren't the tapped into a blind hole? in whcih case how do youo get one out? smack with chisel to split the race?
posted on 18/3/09 at 08:36 PM |
I've removed them in the past using 1 a slide hammer,2 a rawl bolt with mole grips and hammer, 3 a close fitting drift after filling the center
with grease and 4 a dremel type tool. If you get stuck Burtons sell the bearing
nib1980
posted on 18/3/09 at 08:47 PM |
Mine pulled out witha pair of needle nose pliers. got the new one of ebay for £1.50 and pressed it in really easy
flak monkey
posted on 18/3/09 at 08:53 PM |
Take a long bolt with a head that just fits into the bearing. Find something heavy which will slide on the bolt easily and then fit a nut.
Pop the head of the bolt into the bearing and hook it behind (you might need a coach bolt with a slim head to get it in) then use it like a slide
hammer to pull it out.
They usually arent that tight. If its corroded in though you might need to break it out.
Sera
mcerd1
posted on 19/3/09 at 07:48 AM |
quote: a close fitting drift after filling the center with grease
I used this method on the pinto - worked a briliantly, almost no effort at all (unlike everthing else on that rusty old lump)
but the drift needs to be a good fit and idealy more than twice as long as the hole is deep.
I used an offcut from the lathe tha happened to be the right size
[Edited on 19/3/09 by mcerd1]
