wrigglypig
| posted on 23/3/09 at 07:23 PM |
Carb angles
I have a set of GSXR750 carbs fitted to my engine ( you can see them on my photos ) it has just occurred to me do they have to be angled like they
were on a bike or will hey be ok in the horizontal position?
Kev
blakep82
| posted on 23/3/09 at 07:30 PM |
as far as i know, horizontal will be fine. not sure if you can or need to adjust the float bowl, but i think they're designed to operate the
same when a bike does a wheelie, or leans for cornering etc
________________________
blakep82
| posted on 23/3/09 at 07:48 PM |
have a look here
http://www.boggbros.co.uk/gallery.html
these ones are vertical!
whitestu
| posted on 23/3/09 at 08:04 PM |
My ZX6R carbs are horizontal. The only issue I think I might have is getting the idle set up properly, but this may not be due to the angle.
Otherwise they work perfectly.
Stu
| posted on 23/3/09 at 08:07 PM |
You might upset the floats if you have it at an extreme angle. Certainly if its dramatically different you might have to adjust the float tabs.
wrigglypig
| posted on 23/3/09 at 09:47 PM |
Cheers guys I'll leave them alone for the time being
| posted on 23/3/09 at 09:53 PM |
Originally my Honda CBR600FX carbs were at an angle of about 10 degrees off vertical. Now they're about 30 degrees above horizontal.
Still working well!
blakep82
| posted on 23/3/09 at 11:23 PM |
anyone know how well/if they'll work the other way around? ie, with the air filter side lower than the manifold side?
i might need to make a humb back manifold so i can clear the alternator and chassis
vinnievector
| posted on 24/3/09 at 07:46 AM |
my carbs
HI , point of ref for you i have a boggs manifold and its set to around 25 to 30
for a set of R1 carbs .
Are you planning to make your own ?
nstrug
| posted on 24/3/09 at 09:48 AM |
They're designed to work well under heavy acceleration - which is the equivalent of lowering them towards the horizontal.
Nick
DarrenW
| posted on 24/3/09 at 12:30 PM |
For the ranges of angles that we require they will make no discernable difference to the operation of the carbs.
blakep82
| posted on 24/3/09 at 12:33 PM |
but what if they were angled the opposite way to the norm?
